A full cycle is around 20-30 minutes and is timed when the wire is grounded. It can and will turn on and off and will run multiple times or cycles when run off temp sensor. The temp sensor usually does not fail it is the wire that gets burnt in two. An easy fix is to ground the wire and it will run after each shutdown. It can be a pain to splice and put back on sometimes. Grounding is just an easy temporary fix, or permanent if you want to leave it that way.
Rationalization: These rigs are overengineered you know? In addition, a known problem with all one piece intake and exhaust maniflods (jeep I-6's, chevy, ford etc..) are vapor lock and effects of heat on the manifold and carb areas. Consequently, toy engineered the i/e manifolds to be cooled at shutdown for easier restarts and hopefully less stress and damage to the area(s). Sound like a good idea to me especially if I were out on the savanna or desert...
