fireproofing under hood falling off
The hood insulator has a sheet of aluminum foil on the up side of what looks to be a pressed fiberglass sheet, my guess is the aluminum is there for some heat rejection (to protect the hood paint) on top of some noise attenuation from the pad. As a comparison the formed insulator pad on the firewall does not have an aluminum foil layer. A new hood insulator is not very expensive, ~$150 with discount last time I looked, but you would have to get it from a local dealer, too expensive to ship. FWIW.
Napa has them on their wall of small plastic clips!
Maybe so, but Auto Zone didn't.;) NAPA is on the far side of town. It is a bit unusual for a plastic fastener, because of the large head. Obviously, if you can get ones that are 1 to 1 replacements, go for it. I suspect a lot of folks may find my workaround useful.
when i got my 80...in VERY bad shape...the most apparent problem with the paint job was on the hood....this had no insulator inside...and possibly the PO had MANY over heating drives...so much the paint was literally flaking up front. i have a few images in the beginning of my thread. Im not so sure the insulator can smother a fire....but hey...im not an expert here.
Mine was falling off due to broken clips when I bought it. I just removed and threw away. My parts vehicle still has one and I have thought about moving it over to see if I can notice any less noise. I can't see how it would put out a fire.
I found plastic clips that have large head and almost exact match.
Yeah they sell them at any auto parts store, but beware that they are very brittle!
I solved my shredded blanket issue by buying a hood off of a '94 in a junk yard. This also had the benefit of being a straight hood that had never been in an accident. it was even the right color. downside was that it had a really lousy bug deflector on it, so it has a little rust where the deflector rubbed against it
i know this is an old thread but I just saw this new thread about an insulation fire
I H8 Fires!
and made me realize I need to take care of my failing hood insulator pronto!
presume there's no stop gap remedy short of removing the pad?
looks like $150 ish new...
Hood insulation pad
The hail storm broke the clips on mine. I was thinking of just removing the insulation. What is the insulation used for?
Caught mine on fire! So it's not for fire proofing. Any help with engine code 41, and the wires under the intake manifold. I H8 Fires!
It's a sound proofer. Caught my truck on fire when it fell on to the intake. Would advise you to securely fasten or throw away. Could use help on thread, I H8 Fire!
Bag of oem clips from the Beno depot fixed me right up. However only avail as a set of 12(?) I think.
