I use a contact adhesive, get some props that fit between the material and somewhere in the engine bay, then a couple of blobs here and there on the two parts, let them dry (normally 20/30 mins?) and then push the parts together and use a prop to hold it there, have a beer or two and call it done.
I was able to find a clip/fastener that was sized right to fit the hole in the sheet metal, but could not locate one that had the big head needed. I took a fender washer and used the fastener that fit the hole to hold it in place.
For largish tearouts, you could cut a disc out of aluminum flashing and make a giant "fender washer" out of it.
Thanks for the suggestions. I don't think new clips will do the trick because the fireproofing is torn at the corners. The clips are all still intact and OK.
Hmm, thats definitely an option. I'd like to hear the pros and cons from someone on here with more knowledge. I imagine, as insulation, it keeps the hood from completely baking. I wonder if there is a correlation between factory insulation and how fast the clearcoat and paint on the hood wear.
Color is normal, no heat damage from the motor if that is part of your flat earth theory. Clear has been buffed to oblivion, but that is from AZ sun not from the motor cuzzi being absent. My truck is white, so not really noticeable that the cc is oxidized.
I was thinking it was more about soundproofing, models lower down the range would have none further up gets the better package, I think that would make more sense than fireproofing?
My hood clear coat is 50% gone as is the roof clear coat. It started to happen before the hail storm damaged the clips. The liner is still but is slowly falling off.
After the clips broke, the hood closing sound is tinny. It sounded solid before that. I dont remember hood liner on my Toyota mini trucks but the hood closing sound on my 80 sounds like a Toyota pickup hood closing ie: tinny.
having a displeasingly thin, metallic sound.
"tinny music played in the background"
synonyms: jangly, jangling, jingling, jingly;More thin, metallic
"wind chimes can make a tinny sound"
(of an object) made of thin or poor-quality metal.
"a tinny little car"
having an unpleasantly metallic taste.
"canned artichokes taste somewhat tinny"
Maybe when you plop down $36,000 in 1994, Toyota didn't want the sound of the hood sound like a cheap import.
The mat is for sound dampening. Higher spec models get it, lower spec models don't.
If it could suppress or slow a fire, do you think it would not be mandatory on ALL spec vehicles? An actual engine bay fire that could melt the plastic clips to release the mat would already have much of the rest of the vehicle in fireball mode. That's assuming the mat itself doesn't just add more fuel to the fire
