Will add some specs, dont know if you have it in the FSM, but on the wear marks of the fingers on the pressure plate, it says max 0.6mm depth and max 5mm wide. From the picture, it looks like you're within specs.
-If it was me, and I was on a budget, i'd run that clutch if the flywheel is fine.
You're clearly motivated enough to drop the tranny, so why not use what's left of that clutch.![]()
Just put the new clutch in. Why not?
The throw-out bearing hub/fork sloppiness is fine.
What yer is you truck? Gas or diesel? That would explain which clutch fork you have.
If you have a new seal between the transmission and transfer case ten you don't need the hose.
How are your u-joints now? OEM I assume? If they are OK is leave them be, OEM and set-up by Toyota seem to last longer than anything else.
agree.
by tomorrow evening if the stars align just right. Still got to hit the 100km mark so I can re torque my u-bolts again I had seen this suggestion and looked for m12x1.25.... could only find 25mm length in town and checked 4 stores.... so always looking for an excuse to buy new tools!A good trick is to get some long M12x1.25 bolts from the hardware store, zip the heads off and notch them so you can install them wth a flathead screwdriver. I like to put two in the bellhousing, then uninstall when you get two permanent bolts in.
tomorrow!
. Hopefully this was the cause of the sooty glowplug hole on #4. At least I now have a baseline and She purrs very nicely now. Noticeably smoother at idle. Wow... been a while since an update. Had a family holiday and when we got home it was cold so the beast has been neglected for month or two. Not completely forgotten though. I have been out on the newly installed, transmission and so far all is good. This will work fine for me for a while yet!
While its been so cold, I have cleaned and repainted the original air intake housing, it is ready for reinstall.
Front drive shaft yoke/ujoint has been cleaned and re greased. Little bit of play bot reasonably tight. I have yet to install as the PO had 10mm bolts in here, instead of the shouldered 11mm that should have been... Ordered and hopefully next week we can reinstall.
Rear driveshaft u-joints are ready to install new moog after market replacements. Project for this weekend.
I have 4 new NGK glow plugs ready to be installed. Plan on adjusting valves at the same time.
And I finally found some wheels on kijiji that will work for BFG KO2's. 15x8 alloys with 3.25" backspace (-19mm offset). Tires are now mounted and balanced. To be installed soon.
ME TOO! I am amazed at the difference that new wheels/tires make to the ride. Not only looks but way smoother drive!I like these wheels alot more than all the other ones previously posted.
One day I would love to ash fault/concrete the garage and driveway, but that will have to wait till the beast is in tip tot shape first! among other things....Looks great man! Good on ya for roughing it out in the gravel, makes working on concrete a dream come true.
Looking good dude... really liking the look of the new KO2s but have to say those rims really don't due the cruiser justice! We are getting plenty of snow down here for you!!
