I have been restoring an FJ40 for quite some time. I got a new body from California with some serious rust holes on the sides of the tub but with very solid floors (my old one didn't even have any floors). Restoring it has been quite a tedious process given that I can only work on it on weekends and I don't have a storage spot for it. I put it under a tarp when I am finished. The plan is to finish up all of the body work that includes welding. After welding I spray on a few coats of self etching primer. This helps prevent the rust from coming back in the meantime.
When I am done with the body work I plan on taking it to a guy to sandblast it and then epoxy prime and then paint it. I am curious about two things.
I also am curious what you guys do for painting the underside of the tub.
I'd do all of the sandblasting and priming myself but the second I blast off all of the rust I just don't have the time to epoxy prime before flash rust comes back.
- How much has it cost some of you in the past to get your entire tub blasted, primed, and then painted?
- Does the process where I first weld and then spray can prime over make sense?
