F135 Camshaft replacement
South Africa
I tried to search this but could not find an answer.
I see vendors listing the same camshaft for early to late F/2F's ('58 to '86 odd). Is this correct? Are the camshafts for all years the same? I want to replace my 135's camshaft which has a pitted lobe and have spare good 2F and later F camshafts.
There's an oiling hole difference to watch for. There's another thread on that here somewhere.
Thanks for the feedback! I can always have the existing one rebuilt/surfaced locally for a great deal less than I see SOR needs for one. More an itch to get it going quickly after it has been standing probably for some 20/30 years judging by the mould on the roof.
I have it open top and bottom in the Cruiser currently to look for any issues prior to firing it.
It’s the same cam profile as the later F & 2F engines, but has an additional hole drilled in one of the bearing areas to provide oil to the rockers. A lot of a aftermarket cams have the additional hole so they can be used on anything, but some do not.
Thank you so much Splangy!
