When it shut down was the CHECK ENGINE light on or off?Issue keeps happening. Plugs and wires are good.
This time when it happened the engine shut off, waited a few minutes then it started right back up with no problems. Any thoughts ?
STill no Check engine light. Next step is to replace plugs, wires, cap and rotor
I have the same problem, but it has worsened. It will totally clear at times (it is rare that it clear up now). When it is acting up it will run smooth for periods on level but as soon as accelerator is pushed it stumbles incessantly. Starts no problem. Changed wires, plugs, distributor cap rotors, fuel filter, and injectors (mechanic insisted it was a bad injector). No engine codes, no Check Engine Light. I am suspicious of fuel delivery. I have checked the ignition. I will let you know if I find it. I have been driving with the problem but am anxious to fix it. My mechanic gave up.94 LC with 195k, motor is at normal temperature, at highway speed and out of no where the engine will stumble several times then clears ups. No engine codes. Any suggestions would be great.
