Speaking of which, I need to go pick up foam. Did you just place foam on all four sides? The radiator in there had nothing.
IIRC I did all 4 sides on the shroud side. The factory should of had it at the top on the front side for peak performance.
I've seen Beno flex his stock fan into the stock radiator, so it can and does happen.
That's a stocker tho. The 3FE fan is pretty darn rigid. Far more than stock.
...and Beno is an extreme case....LOL
That goes without saying. His motor mounts were probably trashed so the motor prolly lurched forward![]()
If you find the RD is not enough.... Did some load testing with a supercharged 80 this weekend and found removing the hood helped a lot.
