Engine Life Study For School
1995 1FZ all original. 159,000 miles. About to do VC gasket but other than that all original as far as I know. And an 18 year old before me and it still runs, so you know these things can take a beating.
97 1FZ-FE gas 162,000 miles original engine not rebuilt and running strong
Just sold my '95 US-spec - 1FZ-FE, with 194K miles. It burned a quart of oil every 800 miles, slightly low compression in #4 and #5. Otherwise ran well. I highly suspect the valve stem seals were shot - blue cloud after startup. Motor had never been touched internally to my knowledge.
97 1FZ-FE gas 215,000. Head gasket replaced at 212,000. Running great.
'97 1FZ-FE gas, 176,800
no rebuilds, but headgasket popped & replaced @ ~123K, head flattened & valve seats & stem seals done "while I was in there", uses no oil & runs excellent.
new starter @ ~140K
97 1FZ-FE gas, 210,000 Daily Driver,original HG
Current - 97 80 1FZJ 4.5 Liter Supercharged - 155,000 miles
Running Strong....No Head Gasket yet :eek:
96 LX 450 190k regular maintenance. Original HG. Burns oil within spec. Still going strong, and gets worked hard.
227K Miles.. Unmolested Engine.. including HG.
Used to give a puff of blue on start-up, but not since I switched to Delo 400LE. :idea:
Leaks a quart every 2K miles.. that's all.
Abused daily and still going strong! :D
94 1fz-fe. 250k miles. Not rebuilt. Original headgasket. Running strong.
1997 FZJ80 - 170,000 miles - Not rebuilt. All original, still has factory plugs and wires.
1994 207k all original, engine clean as a whistle and drives great
1992 245k all original. Slow but tough
1995 FZJ 1FZ-FE gas 240K. Head gasket replaced about 5K ago. Running great.
Are you going to publish your results on MUD? I'd be curious to see what you come up with.
97 1FZ-FE Gas. 418,000 miles. Daily driver since new. Regular maintenance. Still strong. Still almost original. Changed PHH at 397K, needs fan clutch now.
'95 IFZ-FE gas 185,400 miles daily driver no rebuild, 2nd owner as of 6500 miles ago, i have all the maintenance records since new, original HG
