Hello all,
I am a new Landcruiser owner, but have owned a modified Tacoma for 9 years now. I just purchased a '96 cruiser that has a 1HD-t swap, bald tires and the OME stock height suspension under it. Because of the diesel engine, I'm considering attempting to put 35" tires on it to keep highway RPMs in the optimal 2000-2200 range. (I read that's good idea on here... is it?) What I can't get a good answer on is can I run 315s with that suspension on the street without too much issue? I've read posts indicating everything from "stock suspension with 315s is ok" to "you need 5"+ of lift to run 315s". Long term, I plan on putting a lift on this rig but I need to get tires for it before I drive it in the New England winter. I can avoid rock crawling for the short term but I do travel up to our lake cabin in the winter. This involves climbing over over some small snow drifts. (usually less than a foot of packed snow/ice) What do you guys suggest?
Also, on a side note, the Landcruiser has a Gturbo Grunter on it, with a 14 psi spring for an hz motor. Do any of you have suggestions on whether I can put the 1HD-T 18 psi spring in there and tune for it? (do I need other modifications?)
Thanks in advance,
Thanks in advance,
