- Joined
- Jan 8, 2006
- Threads
- 265
- Messages
- 9,823
- Location
- Ashland, OR
- Website
- www.jeffersonstatecruisers.com
Thanks for all the effort to get this sorted out, and I look forward to the write up!
!!!! Follow along with the video below to see how to install our site as a web app on your home screen.
!!!! Pics of said Tuffy console, please. My puny center console is too cramped.
Here ya go:
http://www.yankeetoys.org/Documents/FJ80_DiffLock_Diagram.zip
Wiring diagram from the FZJ80 FSM. Note that it's a WinZip file, containing 3 GIF images.
NOTE and Edit from 09-03-2008: I have actually done this mod now and found that the colors on the 1997 FZJ80 elocker ECU were different from those referenced in the link above. Everything is explained in this thread:
https://forum.ih8mud.com/79-95-toyo...ng-trd-elockers-fzj80-elocker-ecu-switch.html
This is the wiring diagram for the TRD elocker (look under Tacoma elocker).
If you are using an FZJ80 switch then wire the switch per the FZJ80 wiring diagram. If not, then just install two switches in place of the factory switch and wire between pins 8, 12 and 6 on the FZJ80 ECU.
The other ECU pins should be connected as follows (I think!):
FZJ80 ECU Pin -------------purpose-------------TRD elocker pin
8---------------------Connect to Power
4---------------------MPH switch, leave disconnected
15--------------------center diff lock switch, connect to ground
13--------------------ground
1 (G-L) ---------------power to unlock rear elocker-----7 (LG-R)
3 (G) -----------------power to lock rear elocker-------6 (LG)
11 (G-B) --------------limit switch --------------------3 (LG-B)
10 (G-Y) --------------limit switch --------------------2 (LG-Y)
2 (Y-W) --------------lock indicater -------------------1 (Y-L)
5 (L-G) ---------------power to unlock front elocker----7 (LG-R)
7 (L) -----------------power to lock front elocker ------6 (LG)
14 (L-B) --------------limit switch---------------------3 (LG-B)
16 (L-Y) --------------limit switch---------------------2 (LG-Y)
15 (Y-B) --------------lock indicator-------------------1 (Y-L)
The ECU wire colors indicated are from the factory FZJ80 ECU wiring harness. The TRD elocker pin numbers and wire colors indicated are from the factory TRD wiring harness (factory part number 82127-35100). This is a harness that connects to the two connectors on the TRD elocker and has an 8 pin connector on the other end. The pins and wire colors referenced are from the 8 pin end.
On that 8 pin TRD connector end, you can use 6 conductor wiring to go to the FZJ80 ECU. You will notice that there are 5 connections listed above (7, 6, 3, 2, & 1). In addition, 4 and 8 are connected to ground and 5 is not used.
The lock indicators, ECU pin numbers 2 and 15 can also be connected to indicator lights as shown in the FZJ80 elocker system wiring diagram. I plan on buying 2 LED's for that purpose.
Just to recap parts, I have acquired the following for installation:
2 TRD elockers in 4.56 gearing (41110-3D010)
2 TRD elocker harnesses (82127-35100)
2 TRD elocker gaskets (4218-60050)
4 TRD elocker long studs (90116-08330)
1 FZJ80 elocker ECU
1 FZJ80 elocker ECU wiring connector with pigtail
1 FZJ80 elocker switch
1 FZJ80 elocker switch connector with pigtail
The FZJ80 elocker ECU, switch, and connectors were acquired from Mud members that were parting 80's.
OK, maybe that will answer all the questions for now. If not, question away.
Again, full write-up with pics in the summer.
PS: Teaser photoshop of switch and indicators....
Bad thing about the FJ80 switch is that you cant lock up just the front e-locker. I\ts either REAR, or BOTH.
I'm sure "Cruiser Dan" here on mud can get you one. Check the vender section for American Toyota (I think)
Great thread and I've probably overlooked the answer to my question by getting a bit lost in the detail but .......
I have a '95 FZJ80 w/out differential elockers. The truck does have the "diff lock" for the transfer case but not the elockers for the axles.
I have since acquired a rear axle from a '95 LX450 with an elocker and the stock FZJ80 dash switch but could not locate the ECU as it may have been snagged by the lucky SOB who got the front axle.
My question,
1. Is my "non elocker FZJ80" already equiped with the ECU as it appears to be included in the "diff lock" circuit for the transfer case and if so, where can I locate it within the truck>
The ECU is located in the right kick-panel and no, your 80 does not have the factory ECU included.
2. Does my existing wiring harness have the connections needed to attach my dash switch and axle?
Possibly but I don't think so. Do some searching in the 80 forum as several have done this retrofit. There is an 80 FAQ (top of the 80 forum) and I know that it has a write-up on a complete retrofit.
I was originally under the impression I needed to add an ECU and front and rear sections of wiring harness as well as dash bulbs to retro the locker but after talking with a Toyota parts rep, came away with the impression that I may already have the ECU and harness parts needed.
You will have to install the dash bulbs as well.
Planning on starting the project this weekend and thought I might minimize un needed damage as well as pain and suffering by tapping the knowledge of ih8mud.
thanks for your help.
don't bother with the factory stuff.. Call 12voltguy.com - Home simple, clean, with EVERYTHING you need for your rig.. from plug at diff to switch and panel
