E85
Why?
I could see the benefit if you're boosted. These motors do not have a high enough CR to really make use of any real benefits of E85.
I don't see it causing any harm, it burns clean, but will get slightly worse mileage. We have run higher percentage of alcohol than that, to get OBD1 rigs to pass emissions, without dramas.
You would need to tune for E85 though. You need a lot more fuel than typical gasoline.
I wouldn't bother unless running boost and a tune specific to E85. it might be cheaper but it also has less energy per gallon.
Alcohol is known to eat some gaskets in fuel delivery systems, but unsure if LC would be effected.
E85 also readily bonds with water so you won't have any in your tank.
You could not pump E85 directly into your truck and expect it to run. E85 requires approx 30-35% more fuel for the same power as gasoline. If you put it in your truck you would run incredibly lean, I would expect you would throw codes right away as the stock fuel trim alarms after 20%, after that if you continued to drive I would be you would eventually melt pistons.
  • Like
Reactions: b16
Ethanol diluted gasoline is a colossal eco/green scam and a huge wealth transfer from car owners to agribusiness.
The ethanol is heavily subsidized to the point E85 sells for less than straight gas. This even though the production cost per gallon of ethanol is higher than that of a gallon of gas.
Last data I saw was 45% of the corn used in the US went into ethanol. Not just a lousy fuel but it drives up the cost of food because so much land is tied up growing the corn.
It is an amazing fuel for Forced Induction engines. Huge power and torque and massively increased knock resistance. As more and more cars and trucks go turbo I would expect to see it stick around.
  • Like
Reactions: b16
If you really want to run a Toyota inline-6 on E85, here's the one to do it with.
I ran my Evo 8 on E85 for 6 years and 100,000 miles. I loved the stuff then.
To give some idea, with a relativly stock Evo 8 with turbo back exhaust, + 1000cc injectors and a 255lph fuel pump I was able to bump boost from 19psi to 27 psi and pick up 70whp. After cams my car was making 380whp on a stock turbo. I even ran E85 on my N/A Honda race car since that motor was pushing 13:1 compression ratio, it was really a replacement for race fuel at a fraction of the cost.
This was my dyno chart from basically stock with exhaust to E85, bump in boost and supporting fuel mods + tune
How can that be?
When completely burned a gallon of ethanol generates fewer BTUs than a gallon of gasoline. Fewer BTUs means less energy.
How can that be?
You just use a lot more of it. The alcohol uses tons of heat to vaporize so it has an effect of cooling the intake charge, like a super cold air intake. It also has a very high octane rating. Something like 110 if I remember right.
  • Like
Reactions: b16
Yup, stuff tunes like it is 115 octane even though it really has an octane rating closer to 105.
And yes, it uses a HELL of a lot more fuel. I think I was averaging about 3 miles per gallon when driving it full tilt on track at thunder hill. lol
Thank you!
Nothing in a stock 80 series is engineered for that level of alcohol. A small amount of E-85 should be used (as needed) to get your FZJ-80 to pass emissions. These is a reason for these signs at gas pumps.
Ah....that makes sense.
My Dad was an Army Air Corp mechanic during WW2. They were burning 120 octane avgas. The engines were turbocharged, or supercharged and some had compound turbo-supercharging.
He told me some of the piston engine fighters had a "wartime emergency power" setting on the throttle. The throttle lever had a snubber on it to prevent the pilot from accidentally opening the throttle that far. If the pilot opened it all the way up, it also kicked in a water/methanol injection system to prevent a hole being burned thru the pistons.
This. 110% this. The whole point of ethanol and biodiesel is that they're supposedly renewable. However, any fuel that requires farming to acquire it is worse for the environment than regular petroleum based fuels. Sure they may have less emissions than petroleum, but how many gallons of fossil fuel is burned to bring every gallon of ethanol or bio to market? You've got the fuel guzzling tractors that I guarantee aren't using bio, and then the ride to the ethanol plant, then all the power to convert it (coal powered plants) then the ride to the gas stations. Added to that is the additional cost to tax payers for the welfare queen farmers. Smh. It's absurd.
