Hey this is my first post and am new to the 4x4 world, so forgive me if this topic has been beaten to death. I am looking into the e-locker swap from a 3rd gen 4Runner into my 2nd gen. Now all the info I have found most people state you have to get the ecu for the 3rd member and the factory wiring harness to make it work properly. Why can you not just wire up a switch and relay to it and activate/deactivate whenever you want? Whats the need for the ecu? Isnt the ecu just setting/monitoring parameters such as not allowing lock up if over a certain mph or if you are in 2H/4H? Does the ecu possibly act as a form of "traction control" and look for wheel slip then activate lock up only when needed? I would love to just wire up a switch and relay and call it a day, I hate computers. For me simple and as mechanical as possible is always the best combination. Thanks in advance for any input!
Also I have heard rumor about a cable locker that was only an option on Toyotas in Australia? Is this true? Any aftermarket companies making these for the 8" diffs?
