Downey Cable Locker Conversion
Sporin
Site Addict
Windsor, VT USA
Website
www.ukemafia.com
Both of my electronic actuators appear to be fubar. I am going to make an attempt in the spring to pull them apart and clean them up and get them working again bit if that doesn't happen I am researching replacing them with Downey's Cable version instead.
I've read the posts I could dig up on these here already but I can't seem to find if the dash indicator lights will still function with these? Anyone know if the light is triggered by the actuator or the locker itself?
Anyone have first had experience they'd like to add? I'm just looking right now, as I said this is only a Plan B.
Downey Off-Road
here is a thread where Kurt was dealing with a problem with that system. Within the thread is his ordeal with getting the parts and installing the system.
I personally wouldn't go this route and didn't when my actuators failed. I talked with the previous owner of your truck when I was wheeling with him and he was certain that there was no hope for those actuators. But he might not know what he was talking about either.
I have first hand experience with the Downey cable on my old 4runner. All I can say is that it leaves alot to be desired. I jacked with it endlessly and always had binding issues. In short, it was a bitch to operate
As for the light, I was able to rig up an LED to indicate when it was locked so I'm sure you could figure out how to acuate the oem dash light. My system was a retrofit on the Runner so it didn't have a dash light. Easily do-able but the cable setup sucked in my opinion. I later switched front and rear to electric.
If you look at the wiring diagrams, the dash light has constant switched power and the connection to ground is interrupted/completed by the elocker limit switch. I have no idea what you have to remove to install the Downey cable kit but if it didn't require you to remove/disable the limit switch then it would probably still illuminate the dash light when in the locked position.
FWIW, I have no experience with them but there is no way that I would install a cable locker in an 80 with elockers (even if I had to buy new actuators). Just my opinion.
There is at least one full rebuild thread that I had seen when I was installing a rear '80 locker in the front of my '40. The limit switch has nothing to do with the Downey kit. It's part of the locker assembly. It's the two wire plug on the wiring harness for the locker. You can remove it and see that it's just a spring loaded roller on the end of a short stalk. It indicates the position of the collar.
Here is one rebuild thread. I'm sure you can find more with the search function.
https://forum.ih8mud.com/80-series-tech/95649-rear-e-locker-actuator-rebuild-pics.html
IMHO opinion, the older version of the Downey cable conversion sucked. The current version with the lever appears to be better engineered where you don't have to continuously hold in the cable end until the unit locked. However, they still haven't addressed sealing the end of the cable with a boot or the end of the actuator rod with a proper seal to prevent water/mud ingress.
Good luck.
x2 what Blue said. I am using it for my front and rear locker project on my 40.
Install is real easy, and the new design is way better than their original design, which to be honest sucked donkey balls. The only problem Blue said was figuring out the cable routing, I'll be working that once I get the axle installed. And the 80 interior is not as spartan as the 40, so you'd have to figure out a good solid place to mount the levers
As far as water getting in, it uses the OEM seal on the inside of the mounting block where the shaft goes in to the differential, but it's open on the other end which is I believe the weak spot. For waterprooofing, I just packed the space from the block to the seal with grease, and I might toy around with putting an o-ring at the end of the actuator rod that sticks out of the mounting block. That will probably help keep the great gobs of grease in place. I'd say that if you kept it greased up, you would probaly have no big issues with anything up to maybe some serious stream crossings, and in that case, just add more grease:grinpimp: I'm sure that water would find it's way into my third another way if the cable actuator didn't leak
All in all, a cheap, simple alternative to replacing an actuator motor.
I do have an actuator that I took apart when I was starting my project, you can have the motor assembly and housing, just pay for the ride. The actuator was working prior to me taking it apart.:meh:
If you did do the cable conversion, you could leave your locker position switch and light attached and it would still work.
Thought I'd bump this as spring is nearly here and I'm going to be moving the truck to Job 1 and getting the lockers diagnosed and (hopefully) operable.
Best source for NEW actuators anyone?
Have you tried hooking up a 9 volt battery to make sure it is the actuator motor that has failed? That is the first thing I did when my rear wouldn't lock up. I am glad I did, the locker was actually working fine, it was the position sensor that was bad and not lighting up the dash indicator.
There is a thread somewhere that outlines which electrical connections to apply the 9 volts to on the terminal. If you can't find it let me know and I will see if I can find it.
If you have already done this ignore my post.
