Cable Locker Mod
North Front Range, CO
I fixed my cable locker, the cable at the diff was frozen/rusted.
I then went to water proof the cable end, I went a bit overbaord.
I filled the cable end with MP grease.
I used a CV boot to cover cable end. I then used 3M Ribbon Sealer (the rubber sticky stuff) to wrap the boot to the mounting block. Over that I covered it with RV sealant.
The boot has a weep hold, that I will plug some how, so I can let out any water that gets in there.
The only problem I see is the ribbon sealer might get to hot and start to melt or run.
Is there something I should spray on it to harden it or just use more RV sealant on it?
Is this the mod to a ARB to change it from a air to cable locker? If so, could you please post details? Costs? etc. (I bought a used ARB and want to convert it if possible.)
John
It is a factory locker that was converted to cable. Downey Off Road makes the cable kit.
I added the boot.
I did a search on the Downey Cable Locker and can't find any of my posts about the kit.
I might have to make a new post of the kit if anyone wants me to.
-B-
This is why you controll the GDB and I controll the TURD :D
I tried Downey cable locker, cable locker etc with only newer posts. I went out 600 and 500. I even searched landtoy80 with no luck.
If you say so.... :D
-B-
