You said "the sway bar". There are two sway bars. I notice a considerable difference during on road travel when my front sway bar is removed.I really don't want to go higher with trim packers on the truck. The previous springs were "3.5 lift" springs The Dobinson 4" springs lifted the truck a lot more than I expected.
Sway bar is installed. The swaybar moves freely in the bushings and the bushing are ok shape.
The shocks are new Fox 2.0 Performance shocks for 3" to 5" lift.
I will get pictures with the truck on a level surface.
The spacer would be only to remedy your lean to the left. IH8lean
The springs will settle in over time to an height about 1/4" to 1/2" lower than on install day.
. how do you fill the suspension right now... Im thinking on change my TJM suspension.. its 6 year old .. the ride hight its ok with 305 tires but now I m using 315 tires and ad more weight on the 80.. (new drawer system) so I was thinking on those dobinson 3" progressive coilspring..
