I decided to go with the Dobinsons lift after reading through many threads on this forum. Lots of information about the OME kit as a fan favorite, but I’d previously run their lift on a Tacoma and found it too stiff for my liking. I nearly went the @HemiAlex route and tried to match Bilstein shocks to the OME springs. Ultimately I spoke with a local guy (hi Tai!) who said he loved his Dobinsons setup, describing it as one of the better riding kits available.
My truck had extremely flattened springs, so I was expecting more than the 2” advertised- I ended up with a touch under 6” of total lift before upsizing my tires. I did not install caster shims, but may look into that down the road. The ride is much better, seeing as I am actually ‘suspended’ now.
I ran into one issue that I was able to clear up with a call to Dobinsons in Miami: after the lift I was about 2” high on the passenger rear. I pored over all the ‘cruiser lean’ threads but my truck was beyond that. The rep told me that this suspension is designed with one rear spring 80mm taller than the other. He suspected that I received a RHD kit, and when I swapped rear springs side to side, the lean went away and I am dead level.
Overall I’m pleased with the stance, I need to get it out on a real trail for further review.
Pics:
