Build DIY FJZ80 Low Budget Turbo Build
That's s***house,
I'm sure Steve at efi hardware won't have issues replacing them.
Is it a mission to get the injectors in and out.
They are brand new but pulled out from the supercharged vehicle before they are sold as the vehicles have lpg conversions done on them.
No I assumed the replacements were a single spray.
If they are not yeah don't mess with them and send them back.
Injector Installation
1) Remove throttle body and tie out of the way, no need to disconnect any coolant hoses.
2) Remove upper intake manifold and tie out of the way
3) Remove fuel rail and put in new injectors.
Somehow I was able to pull the egr pipe and install a block off plate without removing the intake manifold. Small hands!
That's s***house,
Steve said there have been 5 bad injectors out of the past 250 which is unusual for a Denso injector. I will be sending them all back.
Are you going to use the same ones or buy different types.
Thanks for the pics of the install.
Is it worth putting brand new gasket back in between the manifold top and bottom?
I couldnt find any other supplier using the 854-450 part number. When I got the package, the number 195500-4450 was on it. I was able to find quite a few places in the states that carried that number.
They also have options for bigger injectors if I ever get to that point.
Fiveomotorsport.com is where I found them and a bunch of other options.
