Now you can make fun of me and my 35's on the 'Con
Dylan
No laughs here man (other than your fro) as I will more than likely be running them myself!
Got some more work on the truck today. Put the weight on the axles and re-measured. rear needed no adjustment and the front needed 1/2 degree on the drivers side after settling.
Pulled them out and welded. Sorry no pic of the rear but it looks like everyone elses.
Full weight, welded, and ubolts in:
Pulled front axle and welded in. Here is how we set it up:
Set axle level side to side and front to back with pinion angle set to 14 degrees:
Then measured side to side front to back at various points to set the pads:
Also took measurments from floor to pad. Most of the set up was done with the axle mounted to the leafs and then mounted to the truck. After the pads were measured on the floor. It sat overnight then full weight on it then everything was remeasured then welded. 1/2 degree is not bad but was corrected as it will make a difference on the highway at 70 mph.
Parts plile getting smaller:
Full weight on rear with 33's. Frame to ground measures 24 3/4" just aft of rear spring hanger:
I figure I have about 3 days left of front axle rebuild, steering, brakes, one diff rebuild with ARB, then flex it out at MetalTech for the shocks/ mounts.
Maybe end of next week? Don't hold me to it
Feeling a bit like this:
clint
