Diagnostic Help Please
Texas
Hey guys. I need help because I am losing my mind.
The Symptoms - Runs a little warmer than normal, idle goes up when you let off the brake (but I just replaced the BB so?), runs a little rich and back fires when you let off the gas.
Things I have already done - found two vacuum leaks and fixed them, new BB and new MC (I did bench bleed like crazy and bled the brake lines), flushed the coolant system, tried the starting fluid trick to find new vacuum leaks - nothing, replaced the spark plugs and cleaned the distributor, replaced vacuum hoses, ran sea foam through the gas tank.... it is still running warm after only 15 - 20 mins of driving, don't feel like I get full brakes and running rich. I feel like it is a vacuum leak but I can't find it. I would love any suggestions
Is your Vac hose to the new booster in good shape?
Time good?
Time good?
Brand new hose and I added a little extra length because the old hose was only 8 inches and I've seen a post talking about it needing to be at least 12-13 inches to draw good suction?
I haven't done anything with the timing because timing is one thing I haven't been brave enough to try and tackle yet.
I would cap any vacuum ports off carb or intake and see if anything changes. Then you’d eliminate accessories like power brakes, vacuum advance, etc. if the problem persists, narrows it down to intake/carb. If it disappears, start hooking up 1 thing at a time until it comes back.
I had a shop looking over it (they couldn't give me much help) and this little guy was unplugged when I got it back (mounted to driver side fender, connects to a vacuum line from the bottom of the carb, runs through this guy and then connects to the charcoal canister on the other side of the motor...) I think it is a form of VTV but.... I searched to the ends of the internet to find what line connects to what port on this (ports are marked S X Y Z) and couldn't find a diagram. I had an old picture I took of my motor that showed part of it in it so I think I have it hooked back up correctly based on the photo and it definitely helped the idle and the brake pressure but I'm still not feeling 100% that I have it right.
Definitely appreciate yall's help. This is my baby and I miss driving her.
So I pulled those lines connected to that VTV and plugged them with bolts and I have stronger brakes, but the idle still goes up when I let off the brakes. I bought a timing light and I have a friend coming later to try to help me try the timing.
if i may ?
where did you source your new brake booster from ?
did i come with a new one way check valve ?
or
you have to re-use your old one from old booster ?
please elaborate in detail ?
matt
if i may ?
or
matt
New BB from Rock Auto (I have tried to order from Ebay and stuff before and gotten wrong or broken parts so I stick with Rockauto.com). Came with new check valve already installed. I put on new vacuum hoses with it.
Hook up a vacuum gauge, sounds like a possible headgasket? I would do a compression check and leakdown. Is it running on all 6 cylinders( im assuming its a f engine?
It's the 2f engine (Dammit I love that motor - she could pull down a mountain with that torque). I haven't tried to run a compression check yet. When I replaced the spark plugs all but 1 were showing signs of running rich (gunky and gas smelling) but I did't mark down which one it was (silly mistake) but once I changed the plugs and cleaned the distributor the loping sound quit and it sounds like it runs even - if that makes sense.
I've done the quick head gasket checks (bubbles in the radiator and dirty coolant and such) , nothing.... and I recently had the head gasket specifically checked by a shop that does only antique vehicles........ but I also TOLD them to do a full diff job and they sent it back saying, "Meh it looks fine"... I am working my way around the area trying to find a good shop I trust to do the jobs I don't feel comfortable doing but... I am not having amazing luck.
I think you still have a vacuum leak somewhere. Does the idle return to normal after it goes up?
As mentioned, plug all vacuum sources and see if it persists. Also, check the carb nuts to be sure they are tight.
do u have a set of HOSE forceps or long needle nose style vice grips ?
if so clamp off the main vac hose to booster temp. and see if any change ?
i would eliminate the possible of a faulty new booster first now
its free to check it , and faulty new rock auto parts have been in my past .............fyi
My bet is the check valve to the BB.
You say it runs warmer than normal- has the radiator cap ever been replaced? I would start there, with a genuine Toyota one.
It is time for good news, bad news, bad news, good news! I decided to just set my entire rig on fire.... really... Front passenger caliper locked up and set a brake line leak on fire... So I am on the side of the road in high heels, I ripped off my blouse and crawled up under my rig trying to put this fire out (threw a giant chunk of fiery grease on my chest and lit myself on fire). Thank god a semi driver pulled over with his fire extinguisher to make sure it stayed out. Got her towed home. Parked her with no major damage. Was up under her making sure she was ok and found the last vacuum leak - dry rotted line. But while she is up in the air and waiting on parts to come in - I am replacing several other things so hopefully we will have all of her symptoms fixed. As soon as the new thermostat set up comes in I am going to run compression testing and timing.... I definitely appreciate all of the pointers.
Or wear a blouse.
