I have the rig 05 LX470. Now I’m looking for drain n full process. What did you end of using ? And how is it working out for you ?I have a 2005 LX470. Anybody use Amsoil ATF. It lists as a replacement for Toyota WS. I am due for a ATF fluid exchange and am considering using this as replacement and doing changes every 100k mi.
Amsoil Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid.
APPLICATIONS
AMSOIL Signature Series Fuel-Efficient Synthetic ATF is recommended for transmissions and other applications that require any of the following specifications:
Ford MERCON* LV, SP; GM DEXRON* VI, DEXRON* HP; Aisin-Warner AW-1; BMW 83 22 0 142 516, 83 22 2 152 426, Dsih 6p805; Honda DW-1*; Hyundai/Kia SP-IV, SPH-IV, SP-IV-RR, NSW-9638, SP4-M; JASO 1A-LV; JWS 3324; Chrysler Mopar* P/N 68157995A, SP-IV; Mercedes-Benz 236.12, 236.14, 236.15, 236.41; Mitsubishi SP-IV, ATF J3, ATF-PA; Nissan Matic-S, Matic-W; Saab 93 165 147; Shell M-1375.4, M-1375.5, M-1375.6, M-L 12108; Toyota WS; Volkswagen/Audi G 055 005, G 055 162, G 060 162 ,G 052 540; Volvo 31256774, ZF S671 090 255
Great to hear back someone who owns 05lx470. Thanks for the reply. Btw where do you get your new gasket. Do you have part number that I can order. Thanks bud. Appreciate your help.I just had a drain and refill done with amsoil low viscosity which is compatible with toyota ws. I am going to work on a progressive switch to amsoil low viscosity. The transmission shop that i went to is a very good transmission shop and they recommended amsoil as well with only doing initially a pan drop and clean with new gasket and then just refill what we lost, then just a drain and fill in a year for a couple years. basically a drain of the pan, refill yearly for a couple yrs to slowly work on getting amsoil in the system. They said amsoil will mix fine with the fluid without issue. They also stated that they would be very cautious on newer transmissions doing a more aggressive flush as a lot of transmissions have valves that do not like flushes and it is better to slowly transition the fluid over. I have a 2005 LX470. I have been driving after the fluid change for 2-3 wks without any issue, trans temps on scangauge are fine without issue. Hope that helps.
I got it a couple years ago from Onur. I cannot remember for sure what the part number was. i procrastinated for 2 yrs before having trans fluid done. when they dropped the pan i had them just clean and replace the filter like Onur recommended. Should be available online i bet.Great to hear back someone who owns 05lx470. Thanks for the reply. Btw where do you get your new gasket. Do you have part number that I can order. Thanks bud. Appreciate your help.
Thanks very much for your input on this. Definitely wary of putting any ATF in there which isn't specifically formulated for it.
I thought most of the current synthetic ATF's aren't explicitly WS compatible?
The T-WS fluid seems to be an exception to that rule. The manufacturer also states compatibility with the LX/LC 5-speed transmission.
