- Joined
- Oct 4, 2008
- Threads
- 193
- Messages
- 6,158
I just acquired the parts from the guru and so did another guy you know that’s local to me. Class is in session.
forum.ih8mud.com
some info on this here if you have not seen it
wiring wiper control on early fj45
hi guys just about to start driving my cruiser after doing a serious of mods and a new paint job and have one last problem ive fitted a 1981 roof window and doors now i have a problem with wipers the black box needs to be wired and i have later model switch has anyone done this and could help as...forum.ih8mud.com
forum.ih8mud.com
That looks awesome. Wish that was around when I was building mine.Would it be just so easy to change the switch to this type model?
Edit: There is said ”negative ground only”, so because the original switch just ground the motor (not feed power to it), I think there is relays needed between the yellow, blue and white wires.
So, if the new switch would only control relays (which would ground the wiper motor), it would work? Or are some mosfets needed too?The switching on the ground side of the motor is a problem. I’ve used relays and mosfets
