For all whom are contemplating using the Mitsuba Wiper Delay Module to get intermittent wipers:
I have received the unit and took it apart to show everyone the guts. This version of it does NOT have the connector on it as shown in a post above, just 6 wires coming out of it. It is also built with discrete components, just like Toyota old school stuff, ie no IC chips. There is a bunch of caps/resistors, three transistors, and a mechanical relay with both NO and NC contacts so it can be used for ground or positive wiper switching systems. It even uses the old brown circuit boards just like the Toyota boards. The funny thing is? It even SMELLS like it's old school
View attachment 1217775 View attachment 1217776
The lack of a connector complicates the implementation of a true plug and play install. Each person will have to ship me their unit
so I can modify it. This will add to the overall cost of this implementation of a wiper delay.
Here is what I propose for the 73-77 FJ40:
Build an adapter using 6 pin connectors that goes between the harness plug and the wiper/washer switch. This adapter also will split out the washer motor signal wire and feed it to the Mitsuba module. This is for the cool feature that when you activate the washer motor by twisting the washer knob, the module causes the wipers to run for two seconds automatically.
Build adapter "tees" that tap into the Cigar Lighter power feed connections for the required +12V and ground signals. These would plug into the existing connectors and allow you to power the module AND still have the lighter work.
The end user will have to unplug the wiper switch and cigar lighter connections, plug the adapter into the wiper switch and wiper harness connector and plug the adapter "tees" into the cigar lighter +12V and ground then reconnect the lighter connectors.
I am going to build one of these this week and test it. I will post back with completed pictures and thoughts.
