Custom Interiors
I have a whole 62 here for parts for the 60 i am working on if the owner changes his mind i may have some stuff for sale won't know for a little while have other stuff that is higher on the get done list.
Have you sourced the HVAC tubes? My understanding is the part numbers differ 60/62.
I have been slowly accumulating 62 dash parts to put into my 83.
I may be real interested as I get into the swap in about two weeks.
Update - I procured a lot of parts and closing on color selections. I am using SEM Elastomeric paint for a unifying color change
I want line up a complete set of parts before I disassemble the current dash to make sure everything fits. I plan on re-wiring the electrical harness once the dash is fully disassembled so I can sort out old vs new “restored” wiring saving space and making future troubleshooting viable
The current Frankenstein dash is functional from a prototype aspect but the 62 set up is going to look so much more correct and finished
I have to admit, I like that double din radio with gauges above. Not seen it before, and it makes sense.
Too bad you are so far away, I’d try to get all your used original dash parts when you are done.
The gauges do work well there and the radio is, well, ok there from a functional standpoint. It is a very tight squeeze to get that unit in there (one needs to “massage” the HVAC duct to make it fit and it doesnt go in far enough due to the HVAC cable placement. To make this work, one would need to 3D print a custom bezel for the whole center section. I was thinking about integrating power ports and LED lights in that custom bezel
I have no AC, so mucking with ducting wouldn’t be a problem. I don’t even have a stereo, just a hole now.
After 12 yrs I only miss the radio a bit.
Does anyone have a line on FJ62 style rocker switches? I am not in need of the stock switches but I have a need to add additional switches for: Camp Light, Roof LED lights, and the water/Methanol Injection system. I would like to have a near match in style to the stock switches so that they look “stock” and fit within the bezel recesses. Thanks
Not answering your question, but somehow I’ve missed this thread over the years. Great build and cool drivetrain combo. I’ve had a few 6.2’s and 6.5’s over the years. Great reliable motors once you understand them.
Amen on the “knowing” part. Along with not expecting “everything
carling is the closest to fit. from what I understand they still require filing of the bezel to get it to fit. I think @NCFJ has done this on some of his builds before and makes them look really clean.
Another day, another challenge: i purchased a 2006 Tacoma overhead console (accessory Meter) that has the ambient temperature and compass read out as well as a much needed maps light and sun glass holder, i have successfully acquired all required connectors and the temperature sensor. This will be installed when I redo the head liner at the upholstery shop. Problem is that it looks like the compass and temp gauge need a signal from a vehicle speed sensor via an ECU (eeewwww ECU!). Has anyone done this mod before? Is there a way to fake the VSS signal?
Those rear tailgate lights are amazing. Did you drill the panels out to fit the lights? Which lights are those?
Hey Comet- I strive to meet all the "correct" Mountaineer expectations. Thanks for the ideas for the interior- just what I am looking for in terms of the interior plan. If I could just find the right "perfectionist" auto upholstery guy.
Carp- I have a National Luna battery system to manage the two batteries. The main starting battery is placed on the drivers side under the hood (the engine bay photo above has the battery and controller placement shown) the controller has the NL fuses (80 amp) per their instructions I ran 0 cables (+ and -) inside the front inner fender then inside the frame rail on drivers side ( prevent accidental damage) then up into the rear quarter panel. These were wrapped full length in large shrink wrap and are softened at each bend to prevent insulation wear/tear and thus shorts. Installed a Blue Sea fuse block for all my Aux loads in the rear quarter panel and had Kevin at Wagongear customize my cover for the fuse panel access door. I used a Marinco (I should have bought stock in West Marine) terminal block at the Main battery to supply cleaner terminal connections. I bought a high output chevy alternator and ran a #2 cable from there to my main battery.
The Aux battery had to be two 6v optimas to fit in the confined space of the quarter panel. Wired them in series. I had to make a custom bracket to secure the two batteries ( Sorry didn't take a pic of that). They are solidly bolted in and both batteries can be removed in a simple straight forward method. I didn't really want to place these on the passenger side as that is the fuel filler/vent side of things. That said, this is a great place for an AUx battery as most my aux loads are in the back of the truck or off the rear bumper
View attachment 1526823 View attachment 1526824
I did cut holes to fit them in. I got these from Gary at Mudrack (Sonoma). However, given the wide adoption of LEDs these days, I would think its an easy thing to find. I did think about LED strips but decided to stay with something more in line with the 1987 styling of the truck. This tail gate light mod is a really useful and relatively easy thing
The 60/62 already has a vss (4 pulse/rot, not sure how that compares to the Tacoma). Its the grn/blk wire that goes to the speedo, as well as the emissions computer in the ds kick panel (for the 60). Hth
