In 4th gear OD on an OEM setup you are at 3.09 ratio on 31" tires.For simplicity's sake: 35s + 4.88s.
In 5th gear you would need 4.33 gears on 31" tires because the 5th gear is taller on the A750 than A343.
New valve body.@Cruisers and Co you doing anything to beef up the trans internals?
I don’t believe a 442, 343 or yes even the 750 is up to the task of 300-500whp. The Aussies for a long time have said don’t push these trans over 250 without upgrades or you will regret it. All our bigger HP builds run manual trans or we limit power in an auto for this very reason. More to the point I believe it is big torque that kills the trans when not built for it.
We can see double, even more torque than that out of the diesels vs say the 2uz.
Cheers
New valve body.
In order to visualize the new transmission think about wearing a pair of longer pants.This is what I meant when I said:
I believe post #2 in this thread addresses that issue.First of all that isn’t the issue and second we have had to remove these because they shift so hard, most people don’t want a shift kit that slams into each gear aggressively.
Cheers
Valve bodies are 100% a part of the issue. Rod goes over it in the video in post #2. 4th and 5th have an inherent issue. The diesel trucks also do not have an option for mid shift torque reduction like we do to keep it alive during the shift which is where most of the burning of clutches comes fromFirst of all that isn’t the issue and second we have had to remove these because they shift so hard, most people don’t want a shift kit that slams into each gear aggressively.
Cheers
This is clear. My question more about how to optimize the entire system with those two new gear ratios, and I believe I have my answer.Simply put the 1st and 5th gear will never fall into OEM specs in terms of RPM for the engine.
besides the VB and better Compushift control we are leaving the trans for the end user to find. An Extreme WAT Rebuild that has been beefed up can be purchased through us if one wants. There is a long lead time to get them here from AUS though@Cruisers and Co you doing anything to beef up the trans internals?
Cheers
People will have the option to make it a complete kit but there are lots of good used low mileage trans out there so we aren’t forcing buying a transmission through usOk so not a complete kit, unless somebody wants that. I have spoke to Rod a number of times about the 750 swap for a 1HDFTE powered Cruiser so pretty familiar.
Cheers
So for reference my current setup with a343 is as follows and I cruise at 75 whenever I’m on the highway. I like the low rpms in when in overdrive. I think 4.88s and 37’s will be the ticket which is where a ton of people are already. The 4:10 w/ 35 crowd could go to 10% UD gears with less hassle than regearing
That’s because the engine Toyota ecu’s (if they have one, obviously FT and DT don’t) can’t interpret the information from the compushift to do that. Ecu Masters, Haltech, Link, motec etc all have that capability.So there you go, since Aussies have supplied me with the info they didn’t mention the mid shift torque reduction differences but did mention burning the clutches inside the trans.
Most our customers like manual, me too, I do get that a lot of people don’t want that conversion in their 80. I would love to see what your turbo kits are like behind the manual 5spd though.
Cheers
