So I tried the plastic flashing method that this guy on YouTube used...
I put my hand over the dash vents with the fan on high and found that the airflow was greatly reduced when I had the flashing on vs off. I was surprised at the amount of suction that AC fan has under the dash when the vent is pulling outside air vs on recirculate. Do you notice any reduction in airflow with the intake guard you used? Can you send a side pic of how the 1" foam elevates the vent guard? I am always trying to DIY if possible, but to avoid the water on the electronics below the dash and related expenses, I may just bite the bullet and buy a new cowl. Did you remove and replace the foam along the entire upper portion of the cowl? I have the M-D expanding 1/2"x 1/2" expanding foam shown in the other threads, but curious what you are using since it looks slightly different than the foam in the pics you posted. Thanks!
That’s the primary reason I won’t consider installing a deflector.. secondary is when the cowl is in good shape and installed correctly this isn’t an issue.
