- Thread starter
- #61
As far as shift levers being too close to the dash, that is simply solved with a cutoff wheel and a welder.
As OGBeno said, no. My 80 has absolutely zero electronic control of anything to do with gearbox or transfer. It is 100 percent mechanical control. And that's how I like it. If I need 4wd, I stop, engage the hubs, select 4H or 4L, take a little bit of power to make sure it's all engaged, and drive. To get out of 4wd I stop, dis-engage hubs, de-select back into 2H mode, power a little to make sure the light goes out, and Bob's your uncle.Do these 5 speed equipped 80 series have
- clutch start cancel button on the dash?
- cant start in gear ability?
Just curious if the TCU takes care of the above items.
With a manual gearbox, why would you want to start in gear?
This is occurring right now, in 2023Back in the day, when everyone couldn't afford a winch, starting in gear was a way to move the vehicle when the engine failed to start. Say you were in the middle of a water crossing and the vehicle failed to restart after stalling. Then you could engage the starter while in gear to use the starter motor to 'drive' the vehicle to dry ground. Not the best scenario, but better than sitting in the middle of the creek.
This is occurring right now, in 2023. A popular way to get over an obstacle after you have stalled the engine at the most inopportune time.
Iffen you don't like living in the United States, just move to a foreign country.It's amazing (and frustrating) how different countries get different specs on vehicles. I think they (whoever makes these calls) made a bad decision when they decided to only offer 80's with auto's here in the U.S. I think the manual would have been very popular. Unfortunately, I think they were initially marketing the 80 mostly to soccer mom's here in the States. I really envy you guys in Australia where the most common 80's were diesels with manuals. Seems like that happens on a lot of vehicles. As an example, we can't get the Hilux here in the States. Some people would argue that the Tacoma is better, but I disagree. The Tacoma might have more creature comforts, but the Hilux wins out in Ruggedness. The Hilux is also offered with the diesel, of course. Sometimes I hate living in the U.S.
Next thing you know, they'll stop offering curb feelers.Here is an interesting read from a couple years ago. 2.4% of the cars sold by CarMax are manuals.
That is a tiny customer base.
Say it ain't soNext thing you know, they'll stop offering curb feelers.
Toyota hasn't sold a diesel vehicle in the United States since 1985. We American buyers told them pass....What we buy is also a function of what they offer us. For instance, in 2022 there were zero new Toyota Diesel sales in the U.S. That's because there were zero offered for sale.
Lately, I've been enamored about an ls3 or some flavor of 4th gen vortec 6.0 with an h152f. Someday.V8 and NV4500 is a great combo in an 80. We did an LS3 with NV in a 60 last year. Super fun to drive.
It will be real close in an 80 NV shifter to the dash. The NV is a short trans. I am sure some guys with 6BTs or 4BTs have done it but the v8 does have to sit a little farther forward than an in-line engine due to heads on the firewall. We like to have an inch or more between the heads and the firewall. Two finger width is great. We also heavily take into consideration trans shifter location.
A 1” body lift on an 80 helps a lot with swaps, for exhaust clearance in particular.
We pretty much do the same as NCFJ says, we put the power train where we like it and build from there. Most swaps kits put the engine to far forward in my opinion. We are also fans of mechanical fans on v8 swaps vs electric.
Cheers
What year 80 series did you source the parts from? And I didn't see and ECU in your parts list? Don't you need the manual ecu?Chiming in on this thread for future readers - I swapped (two of) my 1991 US spec 80(s) over to manual using a factory H150F setup.
I found the transmission and associated parts on gumtree.au (like their kijiji/craigslist). After I got in contact with the guy, we arranged to have him palletize the following that were needed for the swap:
I opted to order new (from Partsouq and Japan4x4):
- transmission (H150F)
- clutch pedal and box
- master cylinder
- slave cylinder
- bellhousing
- engine adaptor plate (not convinced this is needed)
- flywheel
- driveshafts (front is shorter, rear is longer)
- shifters and linkage for transfer case
- clutch pressure plate
- clutch disc
- flywheel bolts
- pressure plate bolts
- pilot bearing
- master cylinder rebuild kit
- slave cylinder rebuild kit
- LHD shift boots
- shifter bushing
- pedal pads
In total, it was $1500AUD for the used parts, ~$500CAD for the new parts, and $1400CAD for shipping. This was in 2020. I checked recently and I would be able to get shipping from Brisbane AU to Halifax CAN for $500CAD.
You have to do a lot of leg work yourself, but don't let the guys who sell you the "kits" make you believe this swap costs $8k USD. I was $3500CAD all in and if I did it again today it would be closer to $2500.
All of that said, it's the best money I've spent on the 80. It's a lot more fun to drive, the deeper gearing, extra gear, and losing the parasitic loss of the auto is a transformation. I really feel I'm getting the most out of the powerplant/platform now. Even with a 3FE, I've towed all sorts of stuff (up to 6000 pounds) on the highway. Is it slow? Definitely. But it does this stuff without "drama" now where before it was a pain in the hole. I don't think twice about hooking on a 3000lb trailer and dragging it wherever.
Acceleration is improved, highway speed holding is dramatically improved (rarely ever a downshift due to always being in the powerband), mpg is improved (about 2-3 mpg across the board), fun factor is improved, versatility of the platform is improved. With my 6500lb touring-kitted 80, I can still knock down 15-17mpg on highway trips if I keep speeds to around 60, manage 13-15 mpg mixed driving being careful, or average 12.5 and enjoy keeping up with traffic.
Downsides are the slack in the drivetrain is a little more pronounced, mostly an early-80 series thing probably.
I knew there was a reason I felt at home and comfortable in Sierra Leone, Suriname, Benin and Cartagena.Iffen you don't like living in the United States, just move to a foreign country.
Like Arkansas.
