Such a simple sentence… (from the front hub section of FSM)
d) Using a brass bar and hammer, tap on the 6 bolt heads and remove the 6 cone washers, plate washers, and nuts.
Tap my A$$! 48 hours soaking in penetrant, tapping, vibrating, trying many of the tricks turned up in search, all were still frozen. I ended up double nutting the studs and removing the studs with an impact gun. Even with that, the cone washers are still frozen to the flange and still needed to be driven out.
I realize this is old hat to many of you but it is my first time.
Just had to vent…
Just had to vent…
