For Sale Clearing out the garage, bunch of stuff + e-locker. Grand Junction, CO
Status
Not open for further replies.
Western Slope, CO
Hey all,
First, lets wish Woody good luck at Hammer '17 tomorrow. There is a entire community wishing he will be victorious.
I am clearing out my garage of all unused parts.
Items are listed with all pictures. As stuff gets sold the details will go away.
Buy pays shipping cost also if needed packing cost.
Reduced
Power Steering pump from a 60 series. Asking $250
Can rebuild if needed.
Fan from 60 series. Asking $10
2F oil Pump. The pickup housing/screen is damaged. $50
Left knuckle steering arm. Asking $20
Emissions Plate and tube from a 60 series. Asking $10 each
Clutch fan pulley from a 60 series. Asking $5
Air switching Valve from a 60 series. Asking $100
I think an F oil pump. Asking $50
Transmission mount for a Pre '85 FJ60. The frames are different as you know. Asking $25
NEW Shackles for an FJ60. Asking $50 for the set.
EGR Vacuum modulator for a 60. Asking $20
FJ60 Vain Pump brackets. Asking $5/ea
41450-60042 Air Tube from an FJ60. Asking $5
FJ60 EGR Cooler with Valve. Asking $100
FJ60 Fuel Line. Asking $10
25601-61040. FJ60 tube from manifold to cooler. Asking $20
17341-61021. Emissions Hose from Air clear to Vane Pump. Asking $5
Price Reduced
Emissions Tubing Cluster. Asking $20. No appearance of holes. Part number 17303-61011
Power Steering Box with Pitman arm from an FJ60 PRE-85 Frame. Asking $150
Rear e-Locker from a 80 Series. 4.11 gears. You're going to need to clean this up before you put it in the housing. Pictured is what will be shipped. If you're thinking about this you'll need the following:
41453-60011 Sleeve, Rear Diff Lock. Retail $250
41456-60010 Cover Plate. Retail $53
84222-12010 Switch Transfer Indicator No 4. Retail $100
And the Right hand axle for the locker. 42311-60110. Retail $637
As well as the computer and Diff Lock Switch.
Asking $675. Boxing and handling charges will apply.
would like the cooling fan..can pm sent
Jimmy,
Will take
Lower rad tube for 60.....$15
Dual wat pump pulley.....$5
Thermost housing.....$30
Cutoff exhaust down pipe.....0
Rad metal tubes --two--$10 + $10.
PMing you shipping info.
The carb is standard issue FJ60. GLWS
Status
