I should have checked closer before. I need the rubber gasket behind the lens too. Not sure if there is an option other than buying whole assembly.
I have bought the complete light just to get the soft parts. Expensive way to go for sure.I should have checked closer before. I need the rubber gasket behind the lens too. Not sure if there is an option other than buying whole assembly.
What year are you working with Chris? I thought it was a ‘65. If that’s the case, your arm should be chrome.Thanks @65swb45
By the time I buy the gaskets from you and order the lenses from Australia I would probably be better to "bite the bullet" and order them from $$SOR.
However now I need also an early turn signal assembly. I just broke the arm off of mine
Not sure if the aluminum can be welded...
Somebody replaced that arm then.Mark, It is my all original 1965 FJ45LWB truck. It has a brass 66 tag.
I wondered if my blinker arm was factory chrome.What year are you working with Chris? I thought it was a ‘65. If that’s the case, your arm should be chrome.
10/69 was the last of the clear lens.
Looking back, I must of been thinking of the end of bib lights... or smoking something funny.Believe it was 9/67 the clear lens was replaced by amber. Not sure when in 69 the bib lights ended. My 10/69 does not have them it also has clearance lights not reflectors on the side. Not sure if the bib lights when away the same time as the reflectors, carburetor and air cleaner changed or phase out individually in a short time. These things are usually what made the difference between 69 and 70 models.
Not sure if these are pot metal or aluminum. I do know the new ones Toyota sells are painted black. I did notice the chrome piece on the two piece hood were both pot metal and steel. Found that by accident. Had a few together and moving a magnetic only a couple stuck.
Whoops…haven’t had my second cup of espresso yet.I think you meant this page.
FJ40, FJ45, FJ55, FJ60, FJ80 and FZJ80 Parking lamp and light bulbs - 1958-1/98 Land Cruiser - Specter Off-Road
Toyota Land Cruiser parts since 1983. From the oldest FJ25 and to the newest Land Cruiser, Non USA or domestic 40 Series, 60 Series 80 Series or 100 Series, SOR has the largest selection of top quality new and used OEM and aftermarket Land Cruiser parts in stock in the world. Specializing in...www.sor.com
If you selling this setup, can u contact me? Thanks you so muchHey everyone, I’m not selling this setup anymore unfortunately. But if I do, I’ll will post it here.
