Choke issues...it pulled out...
Northern Colorado
Well, I had help when removing the engine and my helper had forgot to undo the choke cable...well it seperated, ie the knob came off...
Is it now fooked? It's getting colder here and i prolly need to start using the choke before too long to get her started/warmed up.
It appears that the cable goes into the long knob/handle and is somehow (crimped???) into place? Anyway to fix this?
Make it look like this:
Sorry Dude,
It looks like a one-piece thing, I pulled my spare out...lots of crimps at both ends and I don't see how the inner cable even attaches to the knob.
I had the same thing happen to my 40. I just went to the local pick and pull and cut a full length of e-brake cable. Keep one of the ends with the little knob on it. Then I brought it back home, pulled the choke knob out, fished the cable through the engine side of the fire wall to the inside (the side of the wire without the knob). Once that was done, I unscrewed my old cable (it snapped)and screwed in the new one on the carb. from here, you can then go back into the cab, and test it out to see where it pulls and lets loose, the uncrimp the old wire and just recrimp the new one in when your ready.
$20. 0r less will buy generic cables with knob installed that'll fish through from dash to carb and use the existing clamps and end block at the carb. Most any auto part place will have them. It won't look the same inside the cab and you'd have to remember or mark to know which it is, but it'll work fine.
The generics are usually too long so what you do is pull the cable/knob back out far enough to let you cut the housing to what you need then push the cable back through, attach it at carb and cut off the excess. You can make a nice neat job of it.....or not.
Easy thing.
Thanks for your help, I was thinking about the old Napa route but was going to check to see if anyone knew of a trick of getting it back together. I appears that the inner cable/core slides inside the handle and is crimped or something another.
wasn't sure if I could re-crimp or re-attach that.
I've got the same problem on my 76 with the heater knob and vent knob. Looks like at one time it had gotten stuck. I'll be working on these two issues this weekend and see what I can come up with. I want to retain the stock look.
Here's what a choke knob looks like when it's all apart.
Seems like you could drill out the crimped end, re-insert the inner cable and re-crimp ( or weld or solder or something) and make it work.
it's only around $20 at SOR. That's where I got mine from, cable was frayed.
