Here is the better looking version...
Toyota Land Cruiser Amazon 98-07 FJ100 100 series Off Road Look Snorkel Kit Set | eBay
How exactly does water get separated with that setup?
oops , what an impulse buy ! Thanks a lot Nick . @ $167 including shipping I could not pass it up. I just hope that it is the same thing as what you got. Now you need to help me install when it gets here on the 8th. I hope it doesn't sit on my work bench like the rest of my mods have done.
geocruiser said:What size hole has to be drilled for the main air tube?
I did not order from the same place , but did order off of eBay. It was the same picture and general description. It was interesting that a web address on the back of the snorkel had been some what removed.. I believe the temple was the same and it was packaged by the same methods as the temple is taped to the inside box with heavy tape which can result in ripping the template if not careful. (same as Nicks) It says Land Cruiser on it and all other parts and hardware were the same and looked to match the same build quality. It may be a select run for another company by the same manufacturer, or a second version by the same manufacturer notched for the antenna.
pfran42 said:Did you guys get all the screws mounted or did you install it like Nick did?
jgray said:^ Why was JB weld needed? Did you forget to drill a hole or it was too hard to get to? I've been thinking about ordering one of these because they reviewed so well by so many different people.
Just got the OK from the CFO, and ordered one last night. Same Safari knock-off on ebay, $168.50 with free shipping from CA. For that price, I couldn't pass it up.
What size hole has to be drilled for the main air tube? I would like to source one (hopefully borrow from a friend) before it arrives.
Sent from my Thunderbonner using IH8MUD
Also, since they have been baking in the GA sun for several months, how is the condition of the plastic?
