I don't think lock tite products will work, try some super glue after thoroughly cleaning everything with alcohol.
I was going to say, what a waste of good alcohol...
Isopropyl alcohol 91%, Super glue is moisture cured and the 70% stuff has too much water in it. You can get the stuff at any good pharmacy.
I'm not sure you guys want a permanent bond here. I'm sure the super glue would hold sufficient and you could still remove the plug if needed later.
What about drilling a hole through the plug and housing and using a piece of wire to lock it in? I think someone already suggested it but I haven't heard any yay/nays.
I have a buddy that works at NASA, and he has the stuff they use to attach TEFLON to things!! He said they just scuff up the teflon and apply this stuff and it holds. If it'll do that, it'll hold anything!!![]()
taccruiser97 I would like to buy 2 when they bcome available.
Thread revival...
Nakman.. you have a new gear on the way.
Courtesy of Theriot
Bx
