brass bushing in spindle doesn't fit
Morristown, TN
I bought a 93 80 a few weeks ago and I knew it was in need of an axle job. The side that was bad also had a bad spindle , the threads were messed up. I ordered one from Specter with the brass bushing. Anyways after installing the brass bushing, it won't slide on to the axle, it stops about an inch before getting to the knuckle. I called Specter today and they said the bushings are smaller because a lot of the axles are different sizes and I would need to take some off the inside of the brass bushing. First of all has anyone ever had to do this and if so, what did you use? I thought about trying to pull my old one and putting it in the new spindle but not sure I'll be able to. Anything else I need to know about the bushing? does it need to set in the spindle in a certain position?
Thanks..............10ga
I would return to spector and but OEM. I always go OEM on axle and engine parts
I talked to the service tech at Specter and I told him I thought I would send it back and get them to send me the OEM and he said the bushing is OEM. He said aftermarket or OEM, more than likely you would have to take some off the inside of the bushing. Do you think he's full of it? He said to use a brake cylinder hone
I wouldn't do that after you just bought a part. Do you have your old spindle and does it still fit? you get a great deal on part here from several vendors like Cruiserdan, Beno and a few others. Then you know you are getting the right thing. Cruiserdan has a 94 and you could talk to him about what the guy at spector said. He is at American Toyota in Albq also called Larry Miller Toyota
Yeah my old one slides right on but the spindle itself is shot because the wheel bearing was bad and the threads are shot. I have a pilot bearing puller and was thinking about taking it off and putting on the new spindle. I will ask Dan before I do anything. Thanks for your help
Just sent Dan a PM, I'll see what he says. I also asked him if I could just pull my old bushing and use it.
he is kind of slow on PMs at times. Best to call him in the morning if you don't hear from him. He starts out kind of grumpy on the phone. That is part of his charm :D
He can't be any worse than my wife in the morning ;)
ha ha Bwaaaahahahahhaha he he he
Right
On the other hand he could tell you the part number without looking it up. Half the time he tells me what I don't need and tells me the other parts I will need. The local guys just ask me what I a want and sell it to me then I figure out I am missing something on a Saturday night
Beno is pretty good too, just not as cranky and um not as old and was Cruiser Dans young padawan for several years. Both guys I am proud to call my friends
hijack .. I would love to see the mind of Dan when a newbie call with a newbie questions ( don't get me wrong we all are newbies in one way or another ) ..
Beno, what's your thoughts? I like "not as cranky". I bought this 80 6 weeks ago and seems the closer I get to driving it, something always comes up. I was on a roll Saturday, installed new hoses, belts, new radiator, water pump, front main seal, distributor O ring, and new oil pump cover O ring, started back on the axles around 10pm and then ran into the bushing problem. Me and my buddy were going to work on it until it was ready for the road but hit this roadblock. I just want to drive it
Thanks
... The tech at Specter said some slip right on and others you have to take some off. ...
He is correct, sometimes you have to fit new bushings, normal, have done a bunch of them. Agree, brake cylinder hone and light lube, WD40 or whatever, until it has a nice sliding fit. I prefer the bushing to the needle bearing, lower chance of failure and less chance of carnage with failure. Most likely it is Joint Fuji brand, good stuff.
We spent about 15 minutes using a brake cylinder hone this afternoon and the bushing fits fine. Also got everything put back together so the axle job is finally done.............time to start the next project.
Thanks for everyone's help, I really appreciate it
Well I learned something new. When I replaced mine they slid right on
