Burnouts not possible with the auto unless you take it to the local hockey rink.
I did the valve body mod a few months back, after the mod it shifted insanely hard, now that the turbo is in, it shifts perfect!@Briano
Since you tow, are you feelings the tranny slilppage with the additional engine power output? Is the valve body mod in your future?
I am so glad that this thread that I started over 2 years ago finally came to life and that Joey was the one that made everything happen. I can finally feel like I have contributed something back to Mud! Can't wait to see my first Wits End turbo kit in the wild. Congratulations to everyone that has their kit and has gotten them installed and thanks for the pictures and videos!
I love this turbo so much, that my spare motor is going to get rebuilt this winter, and installed into my lx450 plow truck/ summer guest camper in the spring with a turbo!
My turbo kit that you helped me build is still kicking around CO, now home in Greeley. Pretty sure it’s possible in my Cummins 80....but I don’t trust my axles enough to really try.Burnouts not possible with the auto unless you take it to the local hockey rink.
I have one of those sitting my garage too. Same boat, need to do a rebuild after getting turbo installed.
@NLXTACY and @scottryana Time to start a new thread: WET-1 Motor Rebuild Guide! What, if any, upgrades or substitutions are recommended over OEM parts (newer nozzle injectors, head studs and gaskets), valve work, balance and blueprint, etc. What parts we can get through Joey, and where to get other stuff.
Even if the answer is just stay OEM, it would be better to have a new, focused thread than 200+, soon 300+ pages to wade through.![]()
Some observations after driving the turbo for a few days:
Upon initial driving I had a half-tank of 87 fuel. Mashing the throttle to the floor, I would be getting some engine clatter noise (predetination?).
After topping off the tank with 91, the amount of noise went down.
I’ll re-assess after I have a full tank of pure 91 fuel. Currently 1/2 87 & 1/2 91 octane.
Absolutely F-ing LOVE it!! OMG! It really makes the rig way more fun to drive..
Upon initial driving I had a half-tank of 87 fuel. Mashing the throttle to the floor, I would be getting some engine clatter noise (predetination?). After topping off the tank with 91, the amount of noise went down.
I did install the 14in1 gauge into the rig. Water temp sensor was installed between engine & upper radiator hose. Right into the flat circular area of the engine side before radiator hose.
Comparing my ScanGauageII & new display, the water temps are off from anywhere between 3-7 degrees. Averaging at about 5-6 degrees. 14in1 shows the hotter of the temps.
Consistent freeways speeds of 70-75 mph, rig is running about 200 degrees. Scangauge under 200, 14in1 a little over. It does seems to be running warmer after install. I would be interested to hear what others temps are at. Last night, 11pm. Westbound 91 freeway from the 110 freeway til Bellflower Bl exit. I was getting a very slight temp creep from about 200 to 206 on the 14in1 (5 degrees cooler on OBD2 gauge), when I exited the freeway. It was a flat 10 mile stretch.
Temp dropped several degrees after exiting. Joey what was your experience of the test mules?
I do smell a toasty smell from engine bay.
I do have a lot of new wiring under the hood, so I’m not sure if it’s all just settling in. I do feel the main wiring loom is close to all the new exhaust. I’ve never felt it before to see how toasty it originally got, so I have no imperial data, could just be my OCD worrying. I’m not sure if they make split-loom Insultherm to wrap that, or making a sheath similar to A/C line would be beneficial right there. Just a question/observation.
A/C condenser dripping. Drips onto new down pipe. I’m not concerned at all, but it was a scary sound the first time I heard the popping & sizzling sounds it made just after parking the rig.
Now that I have new gauges, I have an oil temp sensor. It does show hotter than the water temps by maybe 15 degrees. I’m guessing that is what oil temp should be?
AFR’s are typically about 15.
Overall extremely satisfied. A VERY well built, high quality, system & components. A+ Joey & Ryan.
When your transmission shifts it slips into gear, when you instal the shift kit it makes those shifts a lot firmer, meaning less slip/ more instant/ harsh, when you add the turbo, the extra power allows the transmission with a shift kit to act more like a stock trans slipping into gear, basically with a shift kit it didn’t have enough power to allow the transmission to smoothly slip into gear! so I wouldn’t recommend running without the shift kit, I think the consequences would be bad!This is GREAT info and I'll hold off until after the turbo. Newbie question: why is the shifting characteristic improve after the additional hp? I'm sure it has something to do line pressure but I know bubkus when it comes to trannys.
