- Thread starter
- #601
Were those items reasonable in price?
I thought so. $66.52 delivered for all the parts from CruiserDan. 2 gears, seal, new stake nut and washer
I was able to get time to swap in 60 series speedo drive and driven gears in the 74 to compensate for the 33 inch tires. Cruiser dan got me the parts and simple directions. I didn't drain the transfer case, just pulled off the flange and seal and let it run in the drain pan out the flange. by the time i was ready to put the seal back in, it was about done draining. The seal held the rest in. Very straight foward.. Just topped off the fluid.
Dan said it would correct the speedo, so I will find out when I drive it next.
Thanks Dan
Well--that didn't work out very well
At 60 MPH on the GPS, 2200RPM, my speedo now reads 68 MPH! However, the odometer registered 50.3 KM, or 31.23 miles. GPS registered 33.9 miles. 9.5% under. I doubt if the GPS is off. So now I think the BJ70 speedo face is not such a great idea.
went in the wrong direction.
I discovered a long time ago that my GPS is not accurate When used as an odometer. Of coursr it will give accurate distances to the next corner when a destination is programmed but not if your trying to measure distances off the units life mileage counter
74 stock is 4.11
is the GPS out enough to really matter? on a 1500 km actual trip, what would the GPS be out by?
The firsy dri did not know this ... the mileage higher or lower than odometer?
seems to be common practice to use the GPS as accurate measurement for fuel mileage. if incorrect then a lot of posted claims could be questionable.
interesting.
Mine was off about 10%. With the new drive setup it is spot-on.
Mine is running 65MPH/105KPH at 2400 RPM. Indicated and GPS are within a mile or two of each other.
......... and this is on 33" tires?
Yes, 285/75/16 BFG KM2.
yes---the odometer is running slower, with each of the different speedo gears. Those numbers are posted belowI have heard those cups can be touchy. Maybe a speedo shop can check the indicated speed against the mechanical odometer and make them match. I bet right now the mechanical ODO is running slower than the indicated speed on the dial.
I pulled the speedo gears back out. The ones Dan gave me were labeled 6 X 15-17. The one that was in there was 6 X 18. I put the OEM gears back in, and I am back down to the speedo reading 64 at 60 MPH. GPS registered 20 miles, Odometer registered 27.5 kM, or 17 miles
