He is setting me up with everything I need for the build. I will be sure to keep posted as we go.
First of all. A 1980 BJ40 (in Canada). Standard steering.
More to come stay tooned.
I have found out that I suck at welding.
Did you TIG or MIG? I went with TIG. The inner shaft and fittings I had no problem with even as a novice/hobbyist welder. Good prep and having the right welder settings is paramount. Welding the thin outer tubing is tricky and mine weren't pretty. Grinder, a little bondo, and paint - looks good now!
