The brake situation on these trucks doesn't make a whole lot of sense to me. The majority of my experience is in the old Jeep world, most of the full size variety. So Dana 44 axles, with GM type half ton brakes. I did a bit of digging on Rockauto to compare rotor sizes. The D44 had 11.8" diameter rotors, the FZJ80 has 12.25" diameter rotors, and a 2001 1 ton GM has 12.8" diameter rotors.
The reason I bring this up is my past experience. I ran 35" tires on my old Cherokee. It could lock up the tire with little effort rain or shine. Standard front disc rear drum setup. Single piston calipers. Nothing fancy at all. No problems with modulating the brakes, it stopped the way you would expect. The trick to all of this was swapping in a hydra boost system in place of the vacuum booster, which in turn creates more line pressure at the calipers.
The Toyota system by the spec's has it all over 1/2 ton GM brakes. Larger rotor, rear disc, 4 piston calipers up front. There is no reason at all the brakes on the LC should stomp the performance of GM brakes, but they aren't. The issue in my mind seems to be a lack of pressure at the calipers. The ABS module, the LSPV, the vacuum booster all seem to contribute to some degree. In my mind that is the place to start looking for brake improvements. Once that is exhausted, the the BBK path makes a lot more sense.
