You just pry or pull the air switch out, less than a minute.
Details on the slip ons! My big chicken wing has about wore it out...
Isn't the ohm rating for the ML amp such that "normal" impedance (8 ohm) speakers are a problem to run with the factory amp(s)? I've just always heard that's why people are basically out of options WHEN the foam goes bad on the ML speakers - basically, there's only one speaker that will work with the "abnormal" ML components, and that's OEM.So this mod is about $143 but well worth it. I had to,replace my ML 6x9s so I figured I may as well do the other speakers too while I had the door panels off. All are 8ohm and require very little modification, in the case of the mid and tweeters I even used the stock brackets. Took about three hours. Watch online videos on how to remove door panels, if you don't know how, very easy.
Speakers -
6x9 woofers - got these from another post. $57.97
https://www.amazon.com/gp/product/B00N8077VY/?tag=ihco-20
https://www.amazon.com/gp/product/B0002BBP7Y/?tag=ihco-20
https://www.amazon.com/gp/product/B00IIC6CPE/?tag=ihco-20
2" midrange - Picked mainly for their size but sound very decent. Clip or unsolder and reuse harness and bracket. Used some machine screws, washers and nuts to hold the speakers in the brackets. $17.95
https://www.amazon.com/gp/product/B0008JHBOQ/?tag=ihco-20
1" tweeters - unsolder harness, re-use cap and bracket. You have to clip off a small plastic piece but the new tweeter snaps right in. I used some super glue just to make sure it stays put. These are the most expensive component but well worth it. $66.75
https://www.amazon.com/gp/product/B00EO76ZGS/?tag=ihco-20
So much better than stock.
Well this worked out most excellent so I thought I would share. I'll post night picture later. Installed single LED bars in the bumper vent holes. Cutting out the plastic grill inside each opening was easy, just need a sharp knife. Had to grind the short brackets that come with the LED bars a bit but they fit perfectly. Had to buy a 90deg adaptor for my drill to make things easier. Wired to a remote relay kit so I can turn them on/off from the tent when camping. Also didn't require much wiring or going through the firewall. Relay kit comes with two remotes, you can mount one inside the cab too.
2ea 50W 5000lm 11" Cree LED light bars - $34/ea
https://www.amazon.com/gp/product/B00K8K104W/?tag=ihco-20
1ea 15A remote relay kit - $16
https://www.amazon.com/gp/product/B000PI9E4K/?tag=ihco-20
You can still adjust up and down.... night pics to comewith these fog lights retrofitted the way you have them can you still adjust the beam or is it just scattered? Pics would be great at night if you could post those.
