French Press is the way to go....
I just got an insulated french press for camping about six weeks ago. I had tried the perc route, and it was terrible. Maybe it was the cheap, worthless perc I was using, but boiled coffee is awful regardless. So, I wanted to go the route of a travel/camping french press. Most reviews I read on travel/camping presses (REI, Bodum, Nissan, etc.) left something to be desired in losing heat during the steeping process, or the press would allow an unsatisfactory amount of grounds through. The double-walled insulated body is critical to maintaining water temp during the steeping process so that maximum flavor is extracted from the coffee grounds, especially if outside temps are a little more on the colder side. As for grounds leaking through the press, this is virtually unavoidable, but I found some presses do a better job of minimizing grounds in your cup.
I ended up choosing a press by Planetary Design off of
amazon.com.
Amazon.com: French Press Mug - Boot Cut - By Planetary Design Black: Kitchen & Dining
Coffee Press By Planetary Design - DoubleShot, Boot Cut, Desk Press, Table Top and Airscape
Less than $30, which seemed to be the going rate for most middle of the road travel/camping presses. What sold me was the almost flawless customer review feedback on not only the model I ended up getting, but on all the models offered by their company. So far, I have been very pleased. Good design, works great, holds temp well, and they use a filter screen not only at the press plunger (yeah, that's an unfortunate word choice when describing what's in your coffee mug), but it also has a second filter screen at the pour spout to catch any stray grounds. This dual filter method seems to eliminate most all of the coffee grounds from getting into your cup, although there is usually a very fine, dust-like, coffee ground sediment at the bottom of the cup, but I ground my own, so I am probably just grounding too fine. They also say you can drink from the press as a mug with the grounds depressed all the way down, but I would pour into a mug or cup when the coffee is at its peak flavor.
Really simple to use:
- Heat water to just below boiling
- Pour hot water into press that contains your ground coffee
- Let steep for 4-6 minutes with press lid on
- Press down
- Ready to pour and enjoy
I even use the press at home more often than the coffee maker because the pressed coffee tastes much better than drip coffee from the machine. A freshly roasted quality coffee brewed in a press tastes really good.
Just wanted to pass this along. I have no affiliation with this company or product other than I have been enjoying good tasting coffee while camping and even while at home with this press. There is coffee, and then there is good quality, freshly roasted, well-prepared coffee. There is a difference.
Enjoy.
