I have a Red Optima battery....could a fully charged battery not have enough amps to turn over cold engine?
forum.ih8mud.com
Not sure how I’d the battery is but the starter looks pretty old. The battery looks on the newer side. What starter would you recommend?...gear reduction or OEM?
Jeeez! I never noticed that before, You made me go out in the dark to measure mine.First battery posts are different sizes
Ok so I changed out the battery for a new 1/21 dated red optima and still the same problem. The starter just keeps running when I turn the key the starter just keeps going and does not turn over... would this be a potential starter issue or coil? I have put in new plugs and wires. FrustratingThat is an old picture to show battery it self...this how I received the Fj a few months ago. Since then I have replaced the main positive to starter and negative to ground. Both have new battery terminals. I will go out today to have battery tested. Thank you! After all that I am still having problem....and no I did not ignore.
This makes no sense.The starter just keeps running when I turn the key the starter just keeps going and does not turn over...
