Barn Door Barrel Latch
Nashville, TN
Hey guys, anyone got any good pics and dimensions of the barrel latch that latches barn doors to the rear sill??
And pictures of how it goes through the rear sill.
Im putting 75 barn doors on 79...
I appreciate all the input!! Thank you
Goes here
Theres a small piece that is screwed into the rear sill. Mine is welded in. Id put it where it fits best on your truck as everyones measurements are probably slightly different, dont forget to account for weatherstripping if you are going to use it. Your rig is looking great, keep up the great work.
@oldschool4wheeling - now for the creative stuff.. gabbing it up! maybe an industrial ball bearing for the knob. The cone shaped rod can probably just be ground down into that shape.
I'm hopeful that you'll want to use the ambi doors in the winter and the barn doors in the warm months... then I'm really hoping you'll find a way to make it functional without having to remove the ambi doors striker plate. Purely so I can follow in your footsteps design-wise.
@joyRidaz .....you nailed it!! I like the way you think!!
I'm going to do just that, two sets of doors for two seasons.
I have replaced the pins in my amby door hinges. So all I have to do is pull the pin/bolt and not take the hinge off the tub ever again. No more issues with fitting door gaps and such!!
the lower hinges of the amby doors are not in the same location as the upper hinges on the barn doors.
plus you will need fresh holes in the tub for the lower hinges of barns.
you could run the barns, and the lift up upper door...or the best combination, tail gate and lift upper hatch.
