I hate to be the guy that kind of says eh, but really in the case of the 1FZ there just is not any real data on performance changes. In the small block Chevy/LS world, there are easy formulas guaranteed to give you more power. You can open a catalog and find 30 different sets of performance heads, a huge array of cams, and the valves to go with them.
In the 1FZ world there is not a single aftermarket head. There is not a single company that has a CNC ported stock head, some people have ported and lost performance and at least one guy MS90 ported and went to bigger valves and gained huge flow but then you run into over flowing the stock MAF, etc.
I know a lot of people say go to 4.6L that should help but when you look at the numbers it is actually less than 90cc's different. Maybe 2% gain.
100x95 = 4476.8cc
101x95 = 4566.7cc
I think if I had to do it there was absolutely no other way (but there is). I would do:
Complete rebuild
Clean up the head
Intake and exhaust valve +1mm
Go ahead and bore to 101-101.5mm
New Pistons 10:1 compression
Slight timing advance
Header and new intake manifold
Clean up the exhaust (likely to loose some torque but gain a little power)
If you're adventurous get a set of kelford cams, and talk to Landtank about getting his MAF housing (with the idea that the new upgrades will outflow the OEM MAF, and you will need to trial and error bore out the Landtabk housing to match your new flow)
Seems like a lot of money and work when a SC is around $4k and someone here is working on my Turbo plan for around $2-2.5k
