backfiring
we checked the carb. by spraying starter fluid, and detected no leaks, did not try the brake booster.
Will get the compress checked and some vaccum numbers this weekends.
Thanks for the help guys
check timing AGAIN!! My rotor was found to have about 10 degrees of play before the advance started to move.... talk about a PITA. It ran fine right after timing it, time it again to be sure its where you set it. i fought a chevy that was bloving white out the carb, all timing...
Ok so the compression test is done and its not looking good. 1, 4, 5, 6 all around 160 2 and 3 nothing. My roommate was thinking maybe the reason they werent reading is because the valves werent opening properly and that this might also explain why the carb is backfiring the pressure is releasing through the carb. What do you guys think? Other ideas? Thanks.
Clemson55: Ok so the compression test is done and its not looking good. 1, 4, 5, 6 all around 160 2 and 3 nothing. My roommate was thinking maybe the reason they werent reading is because the valves werent opening properly and that this might also explain why the carb is backfiring the pressure is releasing through the carb.
Actually, if you're getting no compression in 2 and 3, then the valves in those cyls are not closing properly or at the right time. Or there's a serious breach in the head gasket. Or there are big holes in your pistons. Or ...(fill in the blank). In any case, if the intake valves are not closing and there's fuel and fire in there, it'll backfire thru the carb.
Alternatively, the valves in 2 and 3 might think they were closing at the right time, but still be off because your timing gears are out of synch as between the crank and cam (although you'd be lucky to mis-align it so as to get compression in 4 out of 6 or be able to get it to "high rpm's" where the backfiring occurs).
RIchard here is my thinking. I really think you have a blown head gasket. Why else would it smoke like it does when it is sitting on forward on a incline. I'm thinking that oil is getting in there from the gasket. Other wise if it were a valve I would think you would be able to tell when checking valve clearance. Best thing I can tell you is to rotate the crank manually and check to make sure cylinders 2, 3 valves are working properly. If they are then it's got to be the head gasket. Good luck.. Call me if you need help.
ClemsonCruiser said:
if the head gasket was blown would he not also be seeing white smoke from the anti-freeze?
Considering that the closest thing to the cylinder is ...........THE NEXT CYLINDER, the answer is...not necessarily.
I concur with the others that a backfire thru the carb indicates that the cylinder is not sealing at the point of ignition. THis means either the timing is sending the spark too soon, or more likely, the cylinder is not sealing relative to the intake manifold. So the question becomes whether the valve is just too tight or burned.
You could try loosening up the intake valves beyond factory specs just to see if it helps.
You can also help confirm the potential breach between the two cylinders by testing them with the adjoining spark plugs installed, then removed, to see if there is any difference in the readings.
Nice to have some old cruiser gods availabe.......... great insight on the trouble shooting Mark.
Well thats true about it being blown from one to the other but where it the oil comming from on an incline. Makes me think a blown gasket or even worse a hole in the piston. I guess bad valve seals could cause this but why only on an incline. There is more to this.
clemson55 said:
Checked the compression with the spark plug in one of the non working cylinders and still nothing.
Unless you can verify that all of the valves are closed on cylinder 3 while you check compression of cylinder 2, this test doesn't really mean much. Not trying to be an ass, but didn't want you to read too much into it here.
Yes, there could be more significant problems like carked pistons, but the facts that
(1) 2 cylinders have lost compression
(2) they're adjacent
(3) they both have ZERO pressure - not just low numbers
(4) you've got backfiring through the carb
lead me to believe that a good chunk of the head gasket between those cylinders is missing.
Well I will find out shortly because I'm most of the way done taking the head off right now.
Marshal if you want to come down this afternoon I'm not going anywhere but between the driveway, the comp, the fridge, and the pisser.
And you were correct sir! Took the head off and found about a inch section between the two cylinders......
Got a head gasket on order from Toyota, will be here next monday, and hopefully this will fix the problem.
