Aussie locker, noisy?
Texas
I'm reading lots of posts on the Aussie. It sounds good and reasonable price.
but is it loud or wierd in turns?
Does it spin the inner wheel in turns?
I'm talking about on pavement.
thanks!
Any out there for sale in good shape?
thanks again! jim
Generally they don't make any more noise that an open diff under most driving conditions. In slow, tight turns, you may notice a clicking noise. They will pop and bang in turns if you go from acceleration to coast and visa versa. All of this is normal.
i have one and love it!!!!!!!!!!!!!!!!!!!!!!
worth every penny i think a locker is one of the first things that should be done to a rig simply because it increases the capability so much.
like started above when turning it will have a clicking or poping sound (with the windows down on my 60 you can hear it easily but it is in no means loud) and occasionally it will make a loud pop/bang/snap kinda noise when you are turning and acel then let off then acel again. but it is completly normal.
and the inside tire will spin through a turn, if you acelerate through a turn you can make it sould like you have some power to an old worn 2f cause it will lock up and drag (so to say) the inner tire.
Another vote for the Aussie.
Yes it does make some noise, especially around tight corners but well worth it when you leave the pavement.
I have one on my blue and white 55
good outways the bad
love mine
just get use to driving with it and youll be fine
Also have to get used to the little bit of wiggle in the rear at highway speed when you get on or off the throttle quick. I have heard thats only with a lift, but way worth the little quirks. Love mine.:)
The wiggle is more the uneven tire pressure!
Does anyone else get a shake on TIGHT, low speed corners as the Aussie ratchets through?
