Thinking maybe an "H" Shape then lift the ends 1/2" so they flow to the middle then elevate front to back?
Yeah, I'll mock something up here at the store today. I've got a few minutes free. I have an idea what I want to do but not sure it will work.
What type of construction? At one point I was looking for a tank to fit between the frame rails on an M416 trailer - never did find anything.
We use these, the RV type pump works well, have it converted to use garden hose. 15 Gallon Spot Sprayer 12 Volt It's main use:
But we do!
Wow! That's really cool! And it didn't look like it changed the patina of the rock. How did you do that? I would carry one in my truck all the time just for clean up purposes.
Like an RV tank. Specify for any inlet, outlet, or pumps, etc.
Not with this guy. Let me know if I can help.So rotomolded polyethylene? Cool - maybe I'll sketch something up. I thought getting a custom tank done would be alot more.
Yeah, I'm thinking more of an "S" or "U" style. And definitely 6". The only downside would be the additional fittings to make the S or U will cost more than straight pipe. But that's not the end of the world. I work at Lowe's so I get a discount!
yes. Im thinking of a rear-facing U with 6" (we're metric here so 160mm) across the front, and the 2 sides reducing to 4" (125mm) but only running about halfway down the rack, need to leave space for tentage at some point. by my calcs it should hold about 40Lt. Im gonna mount it to a board that fixes to the rack for structural support and ease of removal
This is how I did hot water on my old Tacoma, I have the parts sitting in the garage waiting to be installed in my 80.
At idle, the heat exchanger would produce endless hot water, hot enough to scald if you don't have the mixing valve turned down.
The mixing valve is thermostatic so no burns if your water sits in the exchanger when showerhead is off.
View attachment 1410840 View attachment 1410841 View attachment 1410842 View attachment 1410843
I just use the Zodi hot water system. It's not integrated with the truck but it works so well that I wash my dogs with it in the yard at home. Water is hot and pressure is useable.
Amazon.com : ZODI Outback Gear Hot Tap Travel Shower : Portable Camping Shower Gear : Sports & Outdoors
Schedule 40 PVC should be plenty strong without a board to support it. You will have plenty of weight up there. No need to add more.
I will probably leave mine up there all of the time, except in the winter. Just empty.
I tried this, but can't keep joints from leaking. And I'm using a hand pump to pressurize.
If you glue the joints properly then it shouldn't leak. PVC is a thermoset compound meaning you are literally melting the two pieces together. If done properly.
