A while back I brokered a deal on an FJ60 for the daughter of one of our Mud members here when she came to Alaska for the summer right after she graduated college. It is actually a pretty long and interesting story but I'll stick to the sorta kinda relevant part for now.
A couple of years after she purchased it here in Alaska she drove it down the Alaska Highway. Her dad had designated me her "Alaska Dad" at the time, so when I got a call not *too* late the first night I answered immediately. She had only made it to Tok (just over 350 miles)that day and was stopped (stuck?) there with an overheat problem.
I headed out right away with tools, prime suspect parts (Thermostat, fan assembly, coolant and the like), and a sleeping bag. I know the road and have driven it lots, so I made good time and rolled in about 6 hours later and tossed my bag on the picnic table at the campsite she had found (right in town even) and caught a couple hours of shut eye.
She's a smart girl (graduated college at ... 22 IIRC... with TWO degrees and is a dentist now) and she is not a timid girl (last person to summit Denali for the season a couple of years ago now) so I knew from the get go I could trust her (admittedly amateur) evaluation of the situation, but of course I was gonna check it all out anyway.
Checked the coolant levels, checked the fan clutch, checked the thermostat... all good... test drove it and watched the temp gauge climb. Seemingly pretty quickly. I had been using the hand held gauge all along, but we really had not run it long enough before the test drive to even really warm it up. We jumped out and started checking all the interesting points (back of head, middle of head, front of head upper and lower rad hoses, rad itself, thermostat housing, water pump, bypass hose, heater hoses... pretty much everywhere.
(Now this is a 2F we are talking about now, but the lesson applies...)
Every point I checked was nominal and perfectly appropriate for the conditions the rig was being operated under.
IT WAS NOT OVERHEATING, regardless of what the gauge had been and WAS now telling her.
I just realized as I am typing this that I never found out if it was the sending unit or the gauge that was lying to her. Since this happened her father has swapped a 2H into the rig for her and so far it has not made it back up. I *think* it was the sending unit... not sure right at the moment.
But, I had not brought a sending unit or a gauge with me. No matter how many spare parts you carry it is always gonna be the one you left behind that you need.
I did not make a 700+ mile round trip to get the two pieces.
We stopped in the NAPA. If you are coming to or leaving Alaska by road you WILL go through Tok. It may be a small place... but they have a NAPA!
We picked up a handheld infrared temp sensor (the only one in stock/in town) so that she did not have to take mine with her. She headed off down the highway for Illinois with her new tool in hand. For the first day... first couple of days.. she stopped a lot to confirm that the gauge was lying and that everything was in fact copacetic. As time passed she got more comfortable and did not check it nearly as much. And the daily check in phone call switched to the other end of the trip.
So... another overly long story from Mark.
My only point is... if the engine is not showing other overheating symptoms besides what the gauge(s) are telling you... don't rule out that they may be lying. Sending units can fail too, not just the actual dash gauge.
Pick up a handheld infrared sensor. Probably find one in any parts store or big box hardware store for under $30. It is a very handy tool.
Mark...
