- Joined
- Jul 1, 2014
- Threads
- 84
- Messages
- 723
- Location
- Gardnerville, NV
- Website
- www.billetriflesystems.com
Been reading "high idle" threads for two days now... still can't get this thing to lower its rpm. It's off the chart on my portable /timing tach.
Details:
Totally rebuilt engine, probably 25 or 30 minutes of run time on it so far. Rig is a 77' with a 2F.
For the first 15 minutes of run time it was idling great, right at 650, however, I could not see the timing marks with the timing light. I was also getting back firing out of the carb.
Fuel was dumping into the carb as well, after some research, I discover the needle valve is most likely sticking. I replaced the needle valve and valve seat and spring with all new parts. The float was also out of adjustment, the glass viewing port was over full. I adjusted the float per the 2F FsM, now the float is right at the top of the glass.
Fuel is no longer dumping and runs and idles smoothly. Just very high.
I pulled the valve cover to find top dead center on the compression stroke to guarantee that I could reinstall the FJ60 distributor in the correct timing. I drilled a hole in an old distributor cap above hole number 1, so I could see the rotor pointing towards the number one on the cap. I also had the timing needle on the bell housing pointing towards the bb.
@65swb45 said the backfiring through the carb was most likely a poor valve adjustment so I proceeded to do my first ever valve adjustment. All valves needed to be adjusted, all needed to be loosened up.
I put a hole in a piece of cardboard (to slide over threaded section), put it down on top of the carb and it died immediately, no last second attempts to stay running. I'm assuming this means no vacuum leaks. Since I was able to kill the motor with closing off the air, I assumed by restricting the air flow to the carb, I would also be reducing the idle by sealing up the air filter box. I then put new weather stripping around the top of the air filter box. No change.
all three of the adjustment screws are backed off dramatically and some not touching anything.
The air mixture adjustment screw was set about 4-5 turns out from closed, so I turned it all the way back in, then turned it out 2.5 turns.
Vacuum gauge is hooked up to intake manifold and is constantly showing 15inches. The choke breaker is not currently hooked to vacuum as I'm using the 2nd vacuum port off the intake manifold to run to the vacuum gauge. The other vacuum line is hooked to the power valve at the top/front of the carb.
What am I missing here? Will post pics shortly.
Details:
