Alternator location
South Carolina
Okay folks, I have an FJ40 from Venezuela, which was sold as a 1982, and the engine compartment plate and frame share the same VIN. However, when I go to Spector to buy an alternator bracket, the brackets in the parts list do not look the same as what I have. According to the images, and dates in Spector, I have a 1F engine alternator mount, which is on the drivers side, low. If I'm seeing things correctly, that year model mounts on the passenger side, high. I have my power steering pump in that position. Any clues out there as to what I really have? By the way, the reason I'm wondering what I have is because the gentlemen down south, hacked up the existing alternator mount on the engine, and mounted a Delco alternator on the bracket. And I do mean hacked it up. Thanks in advance for any help.
Different markets received different belt-driven accessory mounting configurations. The SOR drawings probably show the North American spec. Your best bet is to find online parts diagrams for your model and then look for the style bracket shown.
Alternator brackets get swapped and/or altered for several reasons. One being, to move the alt to the other side to make room for a power steering pump. Or to upgrade to a non-Toyota high output alt. Sometimes pulleys get changed along with bracket changes.
You would be best to post up pics of what you have. Then decide just what you want to end up with such as return to stock, plan for power steering (if you do not have it now) or plan for a big alt to run a winch maybe. Post up some pics and list your plans.
what you describe is OE for overseas rigs. is your aircleaner housing a round can on the driver side above your alternator?
hopefully the only thing you find hacked up is the alternator mount.
Thank you for that. I was wondering if I just needed to replace the components as they are, rather than concern myself with the specifics of the year. And what you say makes sense, in different markets getting different configurations. I was first concerned that perhaps the engine might have been an earlier model than 1982, but you've put my mind at ease.
Yes sir. Large round can right above the alternator. The mounting bracket and slide adjuster were hacked up, and there are a few other issues I've come across so far, but nothing insurmountable thus far. I am going to have to do a total rewire if anyone has suggestions.
your truck is a GLOBAL SPEC Destination
look at this engine photo its a late model non-usa 2F
i bet you have the same exact set up right ?
do you need a New EM alternator ?
Okay, guys, thanks for all the help thus far, and I am posting some pics now. Again, this 40 is from Venezuela, and is titled as a 1982. Lemme know what y'all think. The alternator has been removed and was a Delco, which required they chop the alternator bracket up in order to make it fit. I have another bracket which looks like what the original likely looked like.
what alternator are you going to put back on the rig?\
from the looks of the setup that was on there, it wasn't lined up very well.
partsouq may have the correct bracket for you, wondering how close a smog pump bracket would be to working
I'd take a look at your engine isolators also, and from a recent post, make sure your windshield is the correct laminated glass.
I purchased another bracket already, hoping this is the correct ne. I was planning on going with original equipment, or close to it, as much as possible. I'll check the glass and, by isolators, do you mean motor mounts? What is partsouq?
Okay, re-wiring is moving along and now I need to buy the correct alternator for this global spec FJ. Anyone able to give me some direction on what model alternator I should buy?
Your FJ40 sounds just like my FJ45 from Venezuela. Probably the same shop. I think I have the alternator mount if yours does not work. 3 puppies advice on the windshield is right on. Mine was tempered and not laminated. I spent 40 years in the Auto Glass business and it is the first vehicle that I have seen with a tempered windshield. Good luck! I see you do not have a heater in your fj40. I was just going to do heat....Now I am installing vintage air heat and ac. I get carried away sometimes. Brian
Thanks. Can you provide any info on what alternator you used on yours?
I'm guessing before your bracket was hacked, it looked like this.
And the alternator looked like this or just like it with a wide pulley.
EDIT: Just for reference, the pictured bracket is what was on my 74 and the alt had the wide pulley.
Yes, that’s what my bracket looked like before the hack and weld job. I have a replacement bracket and adjuster plate, but the alter they jacked the bracket to fit was an old Delco of some sort. Do you have any info on the alternator that’s suppose to fit the correct bracket. It is a wide belt.
The one off my 74 went with that bracket. I just gave it away a few months ago. It was a 40 amp. I'm pretty sure it was the same for at least a few prior years. The one I showed above with the narrow pulley was off a 75. You should have luck in the wanted section as they often get replaced for something with higher amps.
I sure think one for a 74 would work. Check "THESE" out
