Almost quitting
vancouver
Hi all I had to post something because I’m pretty dejected. I just paid $2000 to have a new ECU put into my KAJ 78. I’ve only had it back for a few weeks after being off the road for months yesterday driving home the temperature gauge was almost in the red so I pull over. I was close to home so I let it cool down and made it to home to find out there was no coolant hardly in the system. I filled it up and it seemed to be running OK but I think it’s still losing coolant. I did some research and now I think the cylinder head is cracked. Oh my God I had this thing imported and everything was great and now it looks like it’s going to cost me thousands. I’m not sure what to do with this.
Thousands... thats it? 😅
These trucks are no joke for the wallet, i think you meant kZj 78, BTW
Heads are a wear and tear replacement item on these diesel trucks. Pretty standard.
Do it yourself is what you do, so instead of 10k its 5k, then enjoy it knowing the head is good. And do it alll when you do it, injectors, coolant lines thermostat water pump, fan clutch etc etc etc... its just bolts and fun tokens
Verify the head/headgasket is the issue
Zen and the art of motorcycle maintenance comes to mind here....
1-if you dont enjoy putting in as much time maintaining something as using it you shouldnt own it, OR
2-if you dont like doing maintenance then you need to be able to afford 3 of what you want to be able to afford 1
Welcome to the club! Unfortunately cylinder heads are a common failure on the Prado diesel engines. I took the expensive and labor intensive option and did an engine swap, but replacing a cylinder head and doing some upgrades and preventative maintenance at the same time is fairly straightforward DIY project and will make your rig a reliable vehicle.
I can certainly sympathize with the feeling of dejection, I discovered yesterday that the cams in my old Mercedes W116 have eaten themselves and the parts are NLA. Looks like it is time for a new engine... :bang:
A 70 series in the US isn't really for you if you don't have the one or more of the following: $$, own or have access to a shop, time if you do your own wrenching, and most importantly of all....the passion for it.
Sorry to hear your woes but even a little research prior to buying would have highlighted that the 1KZ is not a robust engine and is prone to cooling issues, and that the auto versions like to blow ECU capacitors. It's unlucky that you get hit by both together, but not unforseeable.
Either you find satisfaction in restoring the vehicle to original running order (and learn to do the work yourself to reduce the cost of a very expensive project), or cut your losses now.
Unfortunately there are a lot of people importing crap vehicles or just trying to flip is as quick as possible with literally zero information about maintenance history. They also tend to pretty them up then sell them without doing anything to them.
Not to pile on as well, but as stated above, the prado line is notorious for overheating and cracking heads. A little bit of research would have shown this to be the case. It's a shame, because outside those issues, the coil sprung prados can be great.
That said, fill up the coolant and go for a drive to get up to temp and check it out. You need to make sure you have it completed filled and then go for a close drive where you can shut it down if you see it overheating. Usually....if you overheat these you've cracked the head as others have stated and you are in for a head, waterpump, hose refresh and making sure the radiator is up to snuff.
At this phase, these are neither cheap, nor overly reliable vehicles. They are old and usually neglected. They are enthusiast rigs that can be a daily once you usually spend a lot of money baselining.
I always suggest baselining every new rig you get without any history. Otherwise this happens.
@LivLandCruizer ,you "did some research and have concluded the cylinder head is cracked." Did you research forums or research under the hood and under the vehicle. A cracked cylinder head generally won't lose coolant as fast as a cracked coolant hose or leaky radiator. Have you inspected your hoses and radiator thoroughly prior to concluding you indeed have a head?
Hi, thanks for your reply. It was helpful. It seems I’m only losing minimal coolant and it’s not overheating. It appears to be running normally without losing any power so it could be a microscopic crack. What do you think about putting a ceramic seal into it to see if that will solve the issue of minimal coolant being lost? Do you have any recommendations for a product? I might as well try it before I start putting a new heads on things. Thanks again for your time Kris.
I think it’s a bad idea.
Fix it right or like others have said cut your losses and move on !😉
